Ecu
Vortex75
Ecu
Post by Vortex75 » Wed Apr 09, 2014 12:08 pm
Hey guys, just a question about the ecu on my Vortex. I know with newer cars that if you disconnect the battery and reconnect it, when you start the car you're meant to do it with no ga pedal and leave it idling for 10 mins so the ecu can remap and set the engine right. I've done it myself with my 98 mirage, I pumped the pedal when I turned it over, it went but wouldn't idle so I disconnected the power, reconnected it, started it with no pedal and it was fine. Are these ECU's the same?
Canny
Post by TOONGA » Wed Apr 09, 2014 8:29 pm
NOTE: Do this on a "cold" engine. Leave it sit overnight and do it in the morning.
1. Disconnect the negative battery terminal cable for 45-60 minutes.
( I leave mine overnight)
2. Reconnect the negative battery terminal cable.
3. Turn off all your accessories.
4. Start the car, but DO NOT touch the throttle at all.
5. Let the car idle for 10-15 minutes, or until the car is at normal operating temperature. Again, do not touch the throttle.
6. Turn the ignition key to the "OFF" position.
from this thread
showthread.php?t=14372
while that thread is for EJ motors, the ECU reset will work for you. ECU
Vortex75
Post by Vortex75 » Wed Apr 09, 2014 10:03 pm
Thanks mate, I'll look at that thread and give it a shot. Problem, my car doesn't want to start without atleast a little touch of the pedal, turns over 2-4 seconds before it fires. Starts straight away when it's at operating temp.
Canny
Post by steptoe » Thu Apr 10, 2014 8:00 am
That might be the idle air control do dad buried deep down right front on block not giving it more air on cold start up. It has a heater coil in it with a time thing ? to allow beast to start cold. You are giving it that extra bit of air on start up with throttle. Mine is same.
Post by NachaLuva » Fri Apr 11, 2014 9:37 pm
TOONGA wrote:NOTE: Do this on a "cold" engine. Leave it sit overnight and do it in the morning.
from this thread
Also make sure A/c & lights are off. Allow to idle until the fans cycle on then off ;)
