Where to buy Weber jets?
Wheres a good place to buy Weber jets? Preferably cheap, don't mind waiting for overseas post.
Thanks
Thanks
- TOONGA
This guy in England has the cheapest Main jets Ive found on ebay
http://www.ebay.com/itm/360516650128?ss ... 1423.l2649
there was another guy in England but he will not ship to Australia any more
the link RSR posted has cheap jets but none to suit the 34ADM (uses the same jets as 32/36)
Thanks, I'll ask them if they do dgv style mains.
Need to read a bit further.. he does 32/36 jetsTOONGA wrote:This guy in England has the cheapest Main jets Ive found on ebay
Like these style?Phizinza wrote:Thanks, I'll ask them if they do dgv style mains.
http://www.ebay.com.au/itm/1-x-74403-06 ... 3077wt_906
That's an idle jet. I read through all the way.
TOONGA, how many turns out is your idle mix screw with those 55 idle jets?
- TOONGA
I have mine at 3and a half turns, 3 and a half is the recommended minimum and 11 is the maximum.
I would say after 11 the screw would probably fall out.
all the info I have on the 34ADM
http://smg.photobucket.com/user/toonga/ ... rby%20pics
I've read for Weber's more than 3 is too lean, less then one is too rich... This might be for only the 32/36 but they are very similar carburettors....
I've read it elsewhere before but this is what I've found tonight
https://www.google.com.au/url?sa=t&sour ... 6utEhEQ-wg
http://www.weberperformance.com.au/pub/ ... tments.pdf
- TOONGA
Wow I was told the other way around, years ago.
I have this book as well if you want it Weber Carburator Manual
Sorry.. I didn't read the 'mains' partPhizinza wrote:That's an idle jet. I read through all the way.
Phizinza wrote:I've read for Weber's more than 3 is too lean, less then one is too rich... This might be for only the 32/36 but they are very similar carburettors....
The more you screw out, the more richer the fuel is.TOONGA wrote:Wow I was told the other way around, years ago.
They all work on the same principle. Vacuum is the main differences.
Edit: but I'm no expert on carbies.. I pay the experts for their help
Sorry, wrote that as I was going to bed = tired. I meant more than 3 is too lean of an idle jet, less then one is too rich of an idle jet. As in more than 3 go down a idle jet size, less than 1 go up an idle jet size.
