GX lib brake upgrade
- cruzingbrumby
Hi guys, I am in the process of doing a turbo conversion to my gx lib, and want to put some good brakes on it. The front cut I used had ABS so the master cylinder is no use, and I don't have the rears to match the fronts. I also want to get rid of the hill holder.
I have found some 99 GT forester brakes that are a good price, I am under the asumption I just need the calipers, discs, and master cylinder, and the brake lines to cut the hill holder out of the circuit, is there anything I'm forgetting or that is going to surprise me ? will I need the proportioning valve as well or are these pretty standard across the suby range
- vincentvega
- cruzingbrumby
- vincentvega
GX rear discs are the same size as turbo ones. The only difference is that the turbo cars have ventilated rears however the GX rotors are solid.
Most people just leave the solid rotors on there, you could fit some ventilated ones if you feel like spending the cash
I have twin piston turbo brakes on the front of my GX with standard rears and its fine, pulls up much better than standard
- cruzingbrumby
- vincentvega
mines an auto - dont have the hill holder
the ventilated rotors are the same size they are just ventilated..
if you want to double check, look up in the DBA catalog and compare the dimensions for the ventilated and non ventilated rotors
- Suby Wan Kenobi
just thought you should know that there is possibly a thickness difference in the ventilated disc compared to the solids. The solids will be thinner. If anything like the variation in other subaru models of similar years the vented disc may not fit inside your rear caliper when your pads are new. I would suggest checking dba records toovincentvega wrote:mines an auto - dont have the hill holder
New plates on the way.
- Chris_Rogers
if you have the front end and harnesses USE the ABS system. the rears are readily available from wreckers (here in QLD anyway.)  though the complete setup may not be cheap ($800 for the WHOLE assy with ABS sensors,stub axles,plates and brakes) turbo ones are vented and are in the DBA book (under BG5 in my case) as vented items. thickness is different and will require the bigger caliper as well.
						- cruzingbrumby
I have most the abs stuff, including harness, ecu, front sensors and hubs, but not sure if I really want it, the car is more an offroader than a street car and not hooning around every where, but could be good when the roos are out, will look into it some more, only need the rear hubs, sensors, and mounting brackets, are the calipers the same or not ? the thickness of the rotor is nearly doulbe in the dba catalouge
						- Chris_Rogers
