gearbox prob
outback_98
gearbox prob
Post by outback_98 » Sun Jan 12, 2014 3:49 pm
Hi guys recently fixed gasket in the engine and did work on gearbox on my 98 auto outback limited.so have put back in and now wont start,acting as if it in gear haven't worked on outback before so any help appreciated guys
Post by NachaLuva » Sun Jan 12, 2014 5:01 pm
Maybe the neutral switch connection is loose?
outback_98
Post by outback_98 » Sun Jan 12, 2014 6:44 pm
Ok so found prob there,have gears and everything else but now post and check engine light are on and it's idling to high,thougths?
outback_98
Post by outback_98 » Sun Jan 12, 2014 6:45 pm
*power light
outback_98
Post by outback_98 » Sun Jan 12, 2014 10:20 pm
also the temp gauge is acting as though it overheating but its not the water in radiator is cool :/
Point
Post by Point » Mon Jan 13, 2014 9:58 am
check that you put your earth leads back properly
98 Forester GX
02 Forester XS Luxury
outback_98
Post by outback_98 » Mon Jan 13, 2014 6:18 pm
Found a vacuum hose lose that brought revs down bit but not enough and yeah earth all good
Post by El_Freddo » Thu Jan 16, 2014 2:16 pm
Which gasket was fixed? Head gasket, water pump gasket, rear oil plate gasket??
If you've done your head gaskets did you get new inlet manifold gaskets?
Also, if you've had the battery disconnected you need to leave the engine to idle to sort out it's idle. Don't touch anything for about 5 minutes, you should note the idle goes up and down before it settles.
If you have had the battery disconnected and didn't leave it to sort the idle, disconnect the battery again, leave for at least 30 minutes then reconnect and start the engine without touching the throttle.
outback_98
Post by outback_98 » Thu Jan 16, 2014 4:02 pm
hi it was the rear engine seal,but ended up having to do something to gearbox also,I will try the battery thing thanks heaps i let you know how I go,i replaced all the vac hoses and that didnt help.
Post by RSR 555 » Tue Feb 11, 2014 2:53 pm
Did you remove the centre console to get to the gear shifter? If so, check that you connected all the plugs back together
