Now I'm back in Aus I have time and a mate's garage to finish off my projects! First up is my rear bar, and if I have time after that it's lift kit and exhaust to be finally completed. Who knows how much of it will actually get done...
So, the lift kit...
I have body spacers ready, no questions on them.
Strut tops: 5mm plate for top and bottom? 8mm round for the spacer itself?
The tops I'm making are 2" (50mm). I have a set front and rear 3" Liberty lift blocks from my last car for the pattern (outback struts onto liberty body) and will use that for dimensions of the hats and bolt pattern. I know the bolt pattern onto the liberty body is different, will just use the template from the bottom
![Smile :)](./images/smilies/icon_smile.gif)
Engine stay rod - current one is 9mm in diameter. Will get whatever is similar at the suppliers... Will cut to length once the lift is in...
Steering Shaft Joint (this thing) - currently, it's 15.5mm in diameter. I'll see what rounds the supplier has. Try and make it as close to visually the same as possible. Also, I plan on cutting the whole length out and replacing it with a new one of correct length, instead of adding a length in of different aged/stressed steel as a cut and shut. Good idea? Will make a jig before cutting it up to keep things to spec.
There are a few things hanging low after body lifts, and I felt my liberty was a little exposed, especially in muddy/rutty conditions where I felt the lift blocks were exposed to direct blows, damaging captive nuts... So after ripping out a captive nut on my liberty when it was lifted, I'm also going to add bracing around the front gearbox crossmember and transverse links, and potentially around the tail shaft's centre bearing and around the trailing arm mounts. Not sure how I'm going to do it... will fit the lift and go from there
I think that's it... What am I'm missing?
Thanks,
Owen
