Wanted: brumby 3.9 ratio diff
I'm after a r160 rear diff with 3.9 ratio preferable in good condition. Happy to organize freight myself.
Muz
Muz
the r160 term you use , not so clear about it myself, but , if your Brumby diff is a normal MY Brumby diff you don't need to specify Brumby for the source. I have an L Series diff in my 84 Brumby, swaps straight in and same goes for the bushed mount at the front of the rear diff - wrecker flogged one from an L Series for me to replace same for Brumby.
Does this mean you have a 4 speed DR 4WD box in your Brumby with 3.9:1 diff in the front ? Or is it a 5 speed 4WD DR from an L Series ?
I am hoarding a 3.9:1 L Series diff for my own purposes but you have reminded me of a task at hand - remove somehow the drive shaft securing spring pin punch stuck in there chasing the spring roll pin
My brumby has a 4 speed DR 4WD box with 3.9:1 diff in the front. So I'm after a matching diff
The diff it currently has is 3.7:1 so the gearbox starts binding the moment I engauge 4wd.
I also have a spare 3.7:1 rear diff if anyone is intrested to trade
- vincentvega
