So, over the last say 6 months, I've had the engine light coming on when decelerating from anywhere over 60kmph. I've ran diagnostics on the computer and found out the error occurring was "24. Idle Control System Malfunction" I've taken my car into Subaru Geelong for a check up. They Seemed to think the issue was a build up of carbon in the throttle body. Gave me some throttle body cleaner and sent me on my way. So I've cleaned the throttle body out... Still the Engine light. Next step was replacing the IAC Valve. I acquired one off ebay from the US. Same Product number and details as the current one in the car. Replaced that, Still the engine light.... So, I've taken it back to Auto Electricians workshop and did the diagnostics again.. Same Error, "24. Idle Control System Malfunction"... He suggests it might be the computer.. So, we look into buying a refurbished computer.. $800, scrap that; we "Hired" one for use and still the same error.. Since then I've bought a reconditioned AIC Valve for $700. 100% working order. New fittings, the works... Yet still the same Error. Eventually after a period of time.. the Engine light stays on longer and longer... won't turn off.. Then will not turn off and idle very rough and feel like its about to stall.. Quick fix of turning the car off for 2 seconds, back on... running like a dream.. Rev's are fine.. Everything else seems to be fine.. Just knowing there is a problem is the issue.. If anyone could possibly suggest any other options other then buying a refurbished engine would be muchly appreciated... Subaru Geelong is stumped and wanted to sell me a new Computer and IAC... Which wouldn't of worked either way. Fast way to waste $2,000 on a car Valued at $5600... I plan on keeping the car till i'm off my P plates.. But would like this problem to be eradicated ASAP. Any Suggestions would be muchly appreciated!
Cheers, Ryan.
