Jetting 32/36Weber on ea81
boowoogum
Post by boowoogum » Fri Oct 28, 2005 9:48 pm
I have fitted a 32/36 Weber (off a Cortina) to the ea81 in my Manx style Beach Buggy. I can't get it to run smooth just above idle i.e. when driving at 60kmh (about 1500rpm). The engine is very stuttery. I have 65 primary idle jet and 145 primary main. Has anyone fitted a similar carb to their ea81 amd what jets were they using?
smoov
Post by smoov » Fri Oct 28, 2005 10:02 pm
according to the old printout of the carby guide from the old site, here are the following reccomendations for the EA81:
Subigiraffe's: prim main: 132, sec main: 130, prim air: 160, sec air: 165, prim idle: 50, sec idle: 55
(EA81, 2 1/4" zorst, emulsion tubes F66 x 2 (cortina carb))
Subanator's: prim main: 132, sec main: 130, prim air: 175, sec air: 135, prim idle: 55, sec idle: 50
(EA81...??? mods)
hope that helps
1998 Subaru Legacy GTB
boowoogum
Post by boowoogum » Fri Oct 28, 2005 10:33 pm
Thanks very much....I'm beginning to think there must be a problem with my carb. I've stripped and cleaned it a couple of times, last time professionally with little or no change. Similarly the jet changes I've made so far have made little difference.????? I'll keep lookingfor answers.
Fang
Post by Fang » Sat Oct 29, 2005 4:49 am
Check the primary idle jet is clear - and hasnt got anything blocking it. You might want to change the size of this jet and see what happens
subgiraffe
Post by subgiraffe » Sat Oct 29, 2005 8:03 am
Check that the base of the carb is FLAT. If not, the motor will run lean and you will never get a good jet setting. With some fine water paper and a nice flat surface (or a piece of glass and some grinding paste) you can flatten the base to ensure an air tight seal against the manifold...
subanator
Post by subanator » Thu Nov 10, 2005 12:19 am
boowoogum, in the links below, the main troubleshooting related problem is vacuum problems. Hope these provide some help and information:
http://homepage.powerup.com.au/~camncat ... subaru.htm
http://homepage.powerup.com.au/~camncat ... gav_32.htm
http://www.triumphspitfire.com/weber.html
Return to “Trouble Shooting”
