Disc brake rear ends
ozbrumby
Post by ozbrumby » Fri Sep 20, 2013 10:24 pm
Great thread from Toonga re the L series disc brake conversion but do the Leone rear ends go across to the Brumby's or only the L series and or Vortex
Post by steptoe » Sat Sep 21, 2013 7:44 am
L and Vortex have a wider track for starters. There has been the odd non MY suspension set up in the back ends of Brumbies etc, may not be ADR approved, or for succesful on road use. If you do take up the challenge document it in here eh!
wagonist
Post by wagonist » Mon Oct 14, 2013 12:15 pm
From what I've heard, they bolt straight across onto the Brumby/MY
Best way to check would be to get the drum brake backing plate off an L series (cos 99% of them have this & they're worth next to nothing), and see if it bolts onto an MY.
If that works, then the disc brake rear end will too because thats a direct bolt on replacement for the L series.
If you do the rear brake conversion, then you should also upgrade the fronts to L series spec. There's no difference between NA/turbo on the fronts.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
Post by TOONGA » Mon Oct 14, 2013 7:07 pm
The di$c brake rear end$ from the L series and or Vortex bolt straight on, as do the Leone rear ends ... I'm assuming you mean the drum rear end from the leone.
or are you talking about the MY leone turbo AWD sedan, with the disc brake rear end? once again this bolts straight on as well.
Post by RSR 555 » Mon Oct 14, 2013 11:21 pm
MY series and L.Series have the same bolt up pattern for the backing plates, whether their drum or disc. If you're converting from drum to disc, you'll need to grab everything from the disc setup, i.e. brake line hoses, bolts, clips, etc.. I would suggest you remove all of the drum parts and throw them in a box and once you have the disc fitted and working correctly.. just throw that box away :)
Post by steptoe » Tue Oct 15, 2013 7:06 am
think oz is actually asking if the rear end suspension assy from L and Vorts go in a Brumby as a bolt in - just not in so many words - only a direct bolt in for the L Series Brumby unfortunately :(
Post by RSR 555 » Tue Oct 15, 2013 10:31 am
Oh.. if it's the rear K-frame from the L in to the MY then the answer is no. Why would you bother? The MY has the adjustable torsion bar as opposed to the L :( Only thing the MY needs is sway bar mountings, which can be welded on quite easierly.
Post by El_Freddo » Tue Oct 15, 2013 6:08 pm
The other thing you need to be really specific about is the hub for the disc to mount on - the 2wd is different to the 4wd unit, this is the only difference in the rear disc setups for the 2 vs 4wd ;)
On a side note, L series self adjusting drum brakes can be swapped onto the MY's but you need the L series backing plate and drums as well ;)
Post by Silverbullet » Tue Oct 15, 2013 7:00 pm
El_Freddo wrote:On a side note, L series self adjusting drum brakes can be swapped onto the MY's but you need the L series backing plate and drums as well ;)
Ah! Thanks Bennie! I've all but given up on finding a rear disc setup along with some Scorpion rims but the L series self adjusters will be better than the manual MY ones. Hopefully with braided lines, L or Lib brake booster and serviced master cylinder rear drums could be bearable :rolleyes:
Post by El_Freddo » Wed Oct 16, 2013 6:14 pm
I swapped out the original MY drum brakes for a set of L series self adjusters on Sunnie the Brumby.
It's a good time to replace the slave cylinders too ;)
