l series clock
ajames
l series clock
Post by ajames » Wed Aug 28, 2013 9:06 am
My clock gains a minute or 2 per day, why??
Car's a l series with ea82t conversion
Post by steptoe » Wed Aug 28, 2013 5:08 pm
Just be happy it works , I've tossed five for not working!. My Brumby clock keeps time to the ABC radio pips to the second for weeks and months on end ! I have a spare to build up as a bedside clock , one day !
Post by Gannon » Wed Aug 28, 2013 6:06 pm
I'd say the crystal has given way and as a result the timing is out.
As for other clocks that fail, its usually the big resistor that goes open circuit. Should be an easy fix for somebody handy with a soldering iron
tambox
Post by tambox » Wed Aug 28, 2013 8:45 pm
Or dry solder joints, very common.
Have a close look at them.
L serious, still.
Tigger
Post by Tigger » Wed Aug 28, 2013 8:53 pm
My Pulsar used to do that too, you would reset it and then a few weeks later it would be 10 mins fast and it would keep getting faster and faster until you changed it again. It was good for making you hurry up though on your way to places, it was like you were running late :)
ajames
Post by ajames » Wed Aug 28, 2013 9:57 pm
Cheers, well I think while it works I'll just leave it be and reset it each week, the stories of non working clocks are worse than one that makes me early!
Thanks
Esubie
Post by Esubie » Thu Aug 29, 2013 1:49 am
Mine's a random number generator. I don't care.
Post by El_Freddo » Thu Aug 29, 2013 10:46 pm
steptoe wrote:Just be happy it works , I've tossed five for not working!
I thought we went through this a few years go Jonno - you don't throw them, pull them apart and re-solder the dry/fried joints and hey presto! A working L series clock once again.
Ajames, I guess your clock is just trying to keep up with the turbo :p :lol:
ajames
Post by ajames » Fri Aug 30, 2013 6:00 pm
Haha no if it was doing that then it'd be running slow!
Post by steptoe » Fri Aug 30, 2013 8:29 pm
El_Freddo wrote:I thought we went through this a few years go Jonno - you don't throw them, pull them apart and re-solder the dry/fried joints and hey presto! A working L series clock once again.
They've not bothered me since, "Bennie" . Got a Volt meter in there instead to monitor the knock sensor or battery Voltage :)
Post by El_Freddo » Fri Aug 30, 2013 11:45 pm
ajames wrote:Haha no if it was doing that then it'd be running slow!
True, but I guess it wants to go faster, just so it doesn't get left behind :p
