LSD L series
tambox
Post by tambox » Sat Aug 24, 2013 7:48 pm
No you cannot just swap the crown wheel, well you could, but;
They are a matched set, refer to OEM manual. 39/10 or 37/10 are the gear sets, hence the pinion teeth are thinner in the 3.9.
The 3.9 diff setup is weaker, thats why they were only released for a limited number of years, thats why they are hard to get (breaks pinion teeth off).
I have broken a few of them, never broken a 3.7 or a 4.1.
Non turbo EA82, the 3.9 should be fine, just be carefull with dumping the clutch, thats when I broke any of mine.
L serious, still.
pzs
Post by pzs » Sat Aug 24, 2013 8:00 pm
El_Freddo wrote:I was under the impression we're talking about an L series here - correct?
I only ask as the L series gearbox can't have the pinion shaft swapped out like the EJ AWD gearboxes can. Unless you're going to use an EJ gearbox in the L series, if that is the subi you have that we're discussing...
That's correct Bennie, stock standard L series with 14 inch wheels, tyres are yet to be fitted...price dependant.
I'll be fitting a disc brake (hopefully) LSD rear end in it...just got to get it from Melbourne to Alice $$$. I want lower gearing.
Tambox, you mentioned in your post, a 4.1...that would be good, how, what from, etc.
thanks for all the info I've been offered.
tambox
Post by tambox » Sat Aug 24, 2013 8:08 pm
A 4.1 is a $custom made$ setup.
It uses a liberty 4.1 crown wheel/pinion.
The pinion is cut and welded to the L series pinion.
Never broken one and given them a hard time.
Only ever done it with centre locking diff gearboxes, but should be ok for any L box.
Very good gear ratios with 14" wheels.
L serious, still.
Mitchhsj
Post by Mitchhsj » Sat Aug 24, 2013 8:19 pm
I wonder if the little auto rx turbo I'm wreaking had a LSD? might swap it over i only have the rear disc brake set up left to do.. cleanest little car i have ever seen, so sad to pull it apart.. half way through putting the dash, seats, centre console and even the carpet in a brumby at the moment. with a vortex ea82t {spider manifold} just to finnish the wiring and inside now and its ready for action :)
pzs
Post by pzs » Sun Aug 25, 2013 8:46 am
tambox wrote:A 4.1 is a $custom made$ setup.
Tambox, where do you have the parts modded, Icahn do the build, but I would need a guy to mod the parts who knows what is needed
tambox
Post by tambox » Sun Aug 25, 2013 9:22 am
The standard dual range L series box has a different shaped pinion to the L series LCD box.
The LCD L series box pinion is similar to a liberty pinion, that is why they can be matched up.
A bit of investigation would be required to see if it is viable with a standard L series box.
You can put the complete gearset from an early Liberty into the L series casings, to give you a 4.1 diff ratio. Then the Liberty Viscous coupling can bolt on the back, will need tailshaft and gear linkage mods.
If you want a locked centre diff, you could try and find a good LCD box, then do the pinion cut/weld.
You can also do the same with a 4.44 front diff.
It is not a straight forward job, gears need machining to fit and their are a range of 1-5 gear ratios to select from.
The welding can be done by an engineering place, shop around, it can be hard to find some one that knows how to do it.
L serious, still.
Post by steptoe » Sun Aug 25, 2013 9:39 am
sounds like someone is in the know !
Post by El_Freddo » Fri Aug 30, 2013 10:26 pm
tambox wrote:A bit of investigation would be required to see if it is viable with a standard L series box.
I don't believe you can - I'm sure the PT4wd pinion shaft has the lower gearset pressed/cast on to it. I've wanted to investigate this further to prove that it is actually the case, but don't have a gearbox available to do it with...
tambox wrote:You can put the complete gearset from an early Liberty into the L series casings, to give you a 4.1 diff ratio. Then the Liberty Viscous coupling can bolt on the back, will need tailshaft and gear linkage mods.
Pretty awesome that we can do this - in the US they don't have dual range EJ boxes to play with.
tambox wrote:If you want a locked centre diff, you could try and find a good LCD box, then do the pinion cut/weld.
Or go with the DCCD centre diff setup, apparently it's a great setup once you've got the controller sorted. But if you go anything EJ in the EA casing you'll need to mod the tail shaft, gearbox crossmember and gearshift linkages ;)
tambox
Post by tambox » Sun Sep 01, 2013 8:18 pm
The bearings for the lower gear set in a standard L series box are pressed onto the pinoin, 3/4 are pressed onto the pinion.
This just changes where to do the cut/weld.
It means instead of just the rear wheels running through the cut/weld, all wheels will.
Know a really good welder?
The LCD and Liberty box gears are on a sleeve that slides onto the pinion, making this mod a lot easier/less stress.
L serious, still.
