Hi,
Purchased a white 92 brumby 5 months ago
came with a canopy, 4 spd trans, 14 inch rims, AC and PS.
i've been enjoying reading through threads on this forum and I'm getting motivated to to some real work on my brumby.
I've got 3 brumbies on the property at the moment.
2 are running and the other is a wreck for parts
I've done a couple of bits to the white brumby so far;
*replaced front drive axles and wheel bearings
*degreased and pressure cleaned engine and bay
*replaced fluids and filters
*set timing to stock specs, 6 deg BTDC (discovered it was out and the cause of a bad rattle)
*sealed cap to distributor with gasket maker because moisture kept getting in
here's some pics
[img]<a%20href="http://www.imagebam.com/image/3471ca267 ... m.com"></a>[/img]
[img]<a%20href="http://www.imagebam.com/image/3b1df2267 ... m.com"></a>[/img]
[img]<a%20href="http://www.imagebam.com/image/6e25a8267 ... m.com"></a>[/img]
[img]<a%20href="http://www.imagebam.com/image/5a6021267 ... m.com"></a>[/img]
Hi from Capel, WA
- hairybrumby
- hairybrumby
links to pics of my brumby
http://www.imagebam.com/image/3b1df2267161666
http://www.imagebam.com/image/3471ca267161665
[url=<a href="http://www.imagebam.com/image/6e25a8267161670" target="_blank"><img src="http://thumbnails106.imagebam.com/26717 ... 161670.jpg" alt="imagebam.com"></a>]<a href="http://www.imagebam.com/image/6e25a8267161670" target="_blank"><img src="http://thumbnails106.imagebam.com/26717 ... 161670.jpg" alt="imagebam.com"></a>[/url]
http://www.imagebam.com/image/e4f517267161674
http://www.imagebam.com/image/5a6021267161677
