MY Brake Booster Upgrade?
so if i was to change my brake booster over what ones can i use or is it best to get another replacement
i have a Liberty Parts car with intact booster and Master cylinder so is it possible to use both of them?
i no the master cylinder would fit onto the original MY booster but i need a new booster neway so a new M/cylinder really wont help me much.
ne1 ever put a new one in? wt do people do when they are puttin all WRX brakes or the likes into their cars do they just use the Cylinders?
Wagon is no longer....
Jeff
hmmm so is it as simple as bolt in to replace the booster?
ie do the mounting bolts line up is it the same set up for the Pedal Linkages and same setup for attaching to the master cylinder?
guess ill be taking the Lib one off tomorrow either way
- Suby Wan Kenobi
Jeff
so is the pushrod adjustment the only thing which needs attention when converting it?
not having touched a booster or brake mast cylinder at work how easy shall it be for me?
obviously the master cylinder needs to coem right off i guess which means i may aswell change my front disks over now have to bleed them neway
dunno if ne1 is interested in this
i got the Lib booster and Master Cylinder to fit on my car
not the easiest thign ive done
if ne1 wants to no nething jsut post up and ill say wt i needed to do.
ill find out tomorrow if im gonna have a working braking system (old booster stopped working and M/clyinder was leaking) didnt have the time to check it out today lol
if it works definitely post it up
EZ30 L series - Monsterwagon
Very interested in this... i will try an remember to take a look when i come over today.
Dave
Dave
hmmm should be able to get away with any combination by the sounds of it.
Dave
Dave
well Booster definetely works now and teamed withed the Lib amster cylinder also makes a huge improvement over the overall braking performance (from wt i can remember when my old booster and M/cylinder actually worked
Stops good now.
Stops good now.
I bought Liberty BOOSTER and MASTER CYL (15/16" bore) from wreckers. I will be able to fit the BOOSTER with a bit of judgling, but I have a Nabco 13/16" currently attached to my Brumby Booster. The Nabco 13/16" Master Cyl has a longer bore compared with the Liberty 15/16" Master Cyl with no brand name. Has anyone tried the Liberty Booster with the Standard Nabco 13/16" master Cyl vs the Liberty 15/16" shorter bore Master Cyl attached re performance braking.
