2001 Forester Auto transmission into 1990 Liberty ???
- Liberty Valance
I have been having difficulties finding a replacement Auto transmission for my 1990 Liberty. A nice low km wrecked 2001 Forester has presented itself to me with the opportunity to purchase to Auto, TCU and rear diff.
This sounds appealing as the 4.11 final drive ratio on the Liberty struggles with the big 27" tyres. The 3.9 forester ratio would be much better and I understand the transmission is generally tougher all round than the older Liberty unit.
So I want to ask the forum community is this conversion possible and what should I look out for?
The transmission will fit mechanically, but electrically they are quite different. The sensors and valvebody are quite different and the TCU and ECU talk to each other in post 1998 models (identified by a round oil filter on the passenger side of the transmission).
More hassle than its worth really. If you found a transmission from a pre 1998 liberty/outback or even impreza (as long as it doesnt have an external oil filter) you should be sweet.
- Liberty Valance
- Liberty Valance
I think Gen2 Outback (94-98 ) have a 4.11 final drive and should be compatible with your car.
- vincentvega
im not sure its that simple though. is a 4.44 auto necessarily geared lower than a 4.11 auto? Depends what the gear ratios are internally.
My solution was to put a 4.44 diff on the front of a 4.11 box. Made 27" tyres feel normal.
PM subaman (Grant) i know he has a good GX auto he wants to sell.
- Liberty Valance
Hi Gannon,Gannon wrote: If you found a transmission from a pre 1998 liberty/outback or even impreza (as long as it doesnt have an external oil filter) you should be sweet.
I have been offered a 95 Outback auto transmission but the drive shafts look different to the Liberty where they enter the transmission. (ie. push in rather than slide on to the splines)
Would it be simple enough to also use the Outback driveshafts in my Liberty?
Also, would I need to run the Transmission Computer from the Outback?
Thanks, Scott
Being an outback it could possibly be a different ratio so the rear diff will have to be changed too. And because outbacks had taller tyres, so the speedo will be slightly out. You might get away without needing to change the tcu. I think you could just change the inner cups to change from female to male joints
AFAIK all the 4spd autos have the same internal ratios.vincentvega wrote:im not sure its that simple though. is a 4.44 auto necessarily geared lower than a 4.11 auto? Depends what the gear ratios are internally.
Also AFAIK all Outbacks have 4.44 diffs.Gannon wrote:Being an outback it could possibly be a different ratio so the rear diff will have to be changed too. And because outbacks had taller tyres, so the speedo will be slightly out. You might get away without needing to change the tcu. I think you could just change the inner cups to change from female to male joints
So you will have to change rear diff to 4.44
- vincentvega
- Liberty Valance
This is all too hard. One bloke swears a 95 Outback Auto will slip straight into my Liberty but then the crowd claims that I will also need to change drive shafts, rear diff and TCU.
Honestly I just want the car driveable, I do 90 kilometers per day on the highway and occasionally drive it on the beach. If I could just find a straight replacement transmission I would have it in the car tomorrow.
- vincentvega
Did you try my original suggestion and pm subaman?
Alternatively i reckon the outnack box will be ok with your original tcu as it isnt vtd. You will need a 4.44 rear diff to go with it. Doesnt havd to be the one from the outback. A gen1 turbo auto rear diff will drop straight in and is a viscous lsd.
Best thing i ever did was switch to 4.44 it made a huge improvent in all areas.
I could not agree more. Everyone worries about big tyres and lift kits, more power, loud exhuasts and flashing lights.
Getting the correct Final drive gearing is one of the best mods you can do, it makes all the other mods you do work as they should, but unfortunelty you cannot see it or hear it, so not many do it.
- Liberty Valance
- Liberty Valance
- vincentvega
- Liberty Valance
Yes not too hard at all but ktm300 is still unhappy that I haven't corrected my gear ratios to compensate for bigger tyres. I guess there comes a point where I'd rather spend Weekends at the beach with my family in a nearly great Subaru then spending weekends in the garage working under a perfect subaru.
