Imprezza low range
hydrowill
Imprezza low range
Post by hydrowill » Tue May 14, 2013 5:16 pm
Hey just wondering what model imprezza 5MT came out with the 1.59 low range?
Can only find snippets here and there but nothing tying to a model.
I'm thinking one of the early imprezza sports wagons?
[SIGPIC][/SIGPIC] H6 outback 5 speed D/R
Post by El_Freddo » Tue May 14, 2013 10:26 pm
None!
The 1.59:1 low range only ever came out in the L series - hence why people do that L series low range conversion.
Best factory conversion you can find is in the 2L foresters and Imprezas at 1.447:1 from memory.
All drive Suparoo in NSW (again, from memory) do a 1.6:1 ratio which is probably just a remanufactured L series gearset that's modified to fit straight into the EJ setup.
hydrowill
Post by hydrowill » Wed May 15, 2013 5:49 am
I've read a few places that there was an imprezza with 1.59. I'll try findustry some liinks.
Post by RSR 555 » Wed May 15, 2013 9:52 am
hydrowill wrote:I've read a few places that there was an imprezza with 1.59. I'll try findustry some liinks.
Best of luck.. I've been playing (pulling them apart) with Subies since 1987 and I'm yet to find an Impreza with 1.59:1 low range.
There is 2 options.. use the L.Series Low Range (which is 1.59:1) or go the Scorpion kit which uses the Albin's 1.58:1 ratio gear set.
For my money, I'd go the L.Series way
hydrowill
Post by hydrowill » Thu May 16, 2013 7:36 am
Yeah sounds like l series is the go hey.
Post by El_Freddo » Thu May 16, 2013 6:11 pm
hydrowill wrote:Yeah sounds like l series is the go hey.
Well, there's plenty of write ups about it, some differ in the way they go about it but they all end up with the same result!
Alpine Raven's write up
Phinzinza''s write up
hydrowill
Post by hydrowill » Thu May 16, 2013 6:40 pm
Thanks bennie :D
