EA82 whats this? Air injection valve?
zebrakombi
Post by zebrakombi » Sun May 05, 2013 2:35 pm
I am replacing an EA82 motor in a Kombi, and the new one has what the Gregorys manual indicates as an Air Injection Valve I think.
The old motor did not have this unit. Where should the outlet, (plastic/rubber pipe) go?
Attached pictures show it is next to distributor and the outlet(?) is circled.
A metal pipe leading to the exhaust comes from it too (as arrowed).
Any help or info would be much appreciated.
Post by Gannon » Sun May 05, 2013 3:39 pm
Air injection valve draws fresh air into the exhaust to help the catalytic converter burn up un-burnt fuel and reduce NOx emissions
In your case, just block off the unused pipe
Post by steptoe » Sun May 05, 2013 9:23 pm
:roll: only ever seen these things on my 92 EA81 . Maybe replicate your previous pollution gear - likely as Gannon suggests, block the exhaust hole up. I think a spark plug shares same thread? Cheap plug up :)
Post by RSR 555 » Sun May 05, 2013 9:53 pm
Gannon wrote:Air injection valve draws fresh air into the exhaust to help the catalytic converter burn un-burnt and reduce NOx emissions
+1
As you don't have it fitted old the old engine, then you want need it on the new one. Was the old engine inspected by the license dept?
Post by steptoe » Mon May 06, 2013 7:01 am
That'd be the rego guys - being in nsw :)
