Rebuilding an ea82
Update?
LOL.. glad to hear it's running again and I gather by purring.. it's running quiet?
Well it's done. Almost.
The engine is in the car and running well. However, one problem I had during the install was that one of the studs on the head that the exhaust bolts onto stripped the thread. So while its all together, there is a lot of exhaust noise atm. I guess I will have to tap a new thread and replace the stud with something oversize. Then it will be done!
So the rebuild all in all:
new main bearings $16
new big end bearings $3
complete engine gasket and seal kit through the donk $105
deglazed the cylinders and installed new rings $41
resurfaced heads $100
new head gaskets (came in engine gasket kit)
valves lapped into their seats
new valve lifters $8each
timing belt kit about $100
spark plugs (alredy had new leads)
new engine ($60) and trans mounts ($50)
Plus things like engine oil, filterm brake fluid etc. Plus postage for some of this stuff.
I think that is most of it. While I had the engine out I also did some rust work and re-sprayed some areas in the engine bay.
Looking forward to getting the exhaust sorted so I can start driving it again!
Cheers, James
Cheers, James
- image.jpg (108 KiB) Viewed 5548 times
Sounds great James, as for your exhaust studs, you can you a Heli-Coil (recoil thread kit)
or this is what I use...
The block really plays a very small part in the oiling system, by this I mean the oil feeds to the crank are faily large and tend not to block up. What is important is getting oil up to those cams and lifters. As long as the oil galleries are cleaned out, then you should be fine. I prefer to use Motul oils and would recommend to you the Motul 4100 Power. This oil goes very well in the older EA engines and I'm very impressed with well it holds up after the engines get very warm (like when we go 4WDing).
http://www.motul.com/gb/en/products/26? ... sity%5D=32
- Silverbullet
Oh bugger
Definitely not what you want to see. Some people might risk it and not give a damn but all I would be able to think about is that pin slipping out and scraping your nice clean bores
Okay guys, new problem. Lifter noise.
Initially the car ran quiet. It then developed a loud lifter tick. I ran a bottle of that lifter free stuff through and it stopped all together. Now it's come back and after an oil change and another bottle of lifter free it won't go away. I installed brand new lifters when I did the rebuild as well as new oil pump seal and timing belts. Could I have an oil pressure problem? The oil light goes out but it's the only thing I can think of.
thoughts?
thoughts?
- littlewhiteute
You're in a lot of trouble.jims wrote:oh o.
I drained the oil this afternoon to do the first oil change. After all the oil drained out I noticed a little metal ring sittin in the plug hole. Turns out its the g-shaped ring that sits in front of the piston pin! The one you remove via the access hole.
How much trouble am I in?
Could be any one of 8.
Sorry to say, engine out.
Gary
Gary
