Intercooler hose swap out/conversions
- T.Farm.Brumby
Hey peeps and peepettes.
Just wondering if anyone had any idea of what fluids intercooler hose will handle? Can't find anything specific on this on the interwebz or on here really so I figured I'd start a thread.
I'm looking to convert most of my hoses and lines in the engine bay to blue intercooler hose. This is mostly for aesthetics but I figure it's better insulated than standard hosing so it will probably give me slightly better performance as well.
My main concern is whether or not radiator coolant or fuel or power steering fluid or any other fluid for that matter would deteriorate or perish intercooler hoses.
Tom.
Tom.
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'89 Brumby "Brumbylicious"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
- Silverbullet
- T.Farm.Brumby
Yeah most of the ones I've found are silicone, but I didn't want to just throw them all in, look at it happily then 2 weeks later get stuck somewhere with half a dozen rooted lines
Cheers for that bullet
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
The silicone hoses are pretty much resistant to most things like petrol, oil, coolant and acids but tap water will eat right through them. Filtered water is even worse, it practically vaporizes silicone hose within seconds
- T.Farm.Brumby
Seriously? So I'm limited to filling my radiator with coolant and antifreeze/water-wetter?Gannon wrote:The silicone hoses are pretty much resistant to most things like petrol, oil, coolant and acids but tap water will eat right through them. Filtered water is even worse, it practically vaporizes silicone hose within seconds
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
Bit worried what's in Gannons water up there
I run a bloody expensive per meter but cheaper than factory hose on the turbo for coolant etc - no problems. Most hoses have a rating to use as your guide, but silicone is sort of heat proof- think I was the industry pioneer for silicone as exhaust gasket sealer (coz it was there and paid for) Would not use it for power steering high pressure side though until confirmed it is within spec. Lucky you if you can get radiator hoses to fit to silicone.They almost always seem to be in imperial quarter inch increments, then Mr Hose of the UK has pipe by the mm ID from memory
- T.Farm.Brumby
Thought that was a bit suss hahahasteptoe wrote:Bit worried what's in Gannons water up there![]()
Well I'll look into it a bit further, I've found a couple things online where they do it in 8th and 16th increments but I don't know how expensive/available that would besteptoe wrote: I run a bloody expensive per meter but cheaper than factory hose on the turbo for coolant etc - no problems. Most hoses have a rating to use as your guide, but silicone is sort of heat proof- think I was the industry pioneer for silicone as exhaust gasket sealer (coz it was there and paid for) Would not use it for power steering high pressure side though until confirmed it is within spec. Lucky you if you can get radiator hoses to fit to silicone.They almost always seem to be in imperial quarter inch increments, then Mr Hose of the UK has pipe by the mm ID from memory
Will keep you posted
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
- littlewhiteute
I find that very hard to believe.Gannon wrote:The silicone hoses are pretty much resistant to most things like petrol, oil, coolant and acids but tap water will eat right through them. Filtered water is even worse, it practically vaporizes silicone hose within seconds
You're saying a cooling system hose set I have for my WRX can handle any fluid EXCEPT water?
Most premixed coolant is water based.
Gary
Gary
littlewhiteute wrote: You're saying a cooling system hose set I have for my WRX can handle any fluid EXCEPT water?
- T.Farm.Brumby
+100000 :dgannon wrote:
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
LOL.. pretty nasty stuff that waterGannon wrote:Filtered water is even worse, it practically vaporizes silicone hose within seconds
Tom, silicone is the way to go
- 60766244
Aahaha, this thread.
Silicon hoses get used a lot up north for the real nasty large machines up there.
Not sure what they use for hydraulics though, most of it is a rubber external compound with different colours (presumably types) of rubber layered in with steel mesh.
Let us know how much it all cost, and of course, pictures.
- T.Farm.Brumby
Wilco.60766244 wrote:Aahaha, this thread.
I'll be trying to do it on the cheap as usual.
If it's not worth it, I'll just get the stock stuff for the harder to find bits
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
