Stretch's Brumby.
Post by steptoe » Sat Mar 16, 2013 6:54 am
tell you what, if you look at the space under the tray at the back wall closer to the floor of inside there is some good room to have speakers mounted clear of the floor . Some reinforced metal speaker boxes riveted (lots to keep strength) and sealed into place might be cool ?
phantomD
Post by phantomD » Sat Mar 16, 2013 11:12 am
Stretchomatic wrote:Is it normal for the brumby to have a nose down stance or are my front springs shagged?
Perfectly normal, mine is the same and it's never been touched.
Stretchomatic
Post by Stretchomatic » Fri Mar 29, 2013 9:07 am
Just wondering about the numbers on the speedo. The 1 at 45kmh, the 2 at 80kmh and the 3 at 110kmh... im guessing its a shift guide since i dont have a tacho... what sort of revs would it be doing at those speeds?
And does anyone have the hillhold function i read about in the user manual?
Cheers, Stretch.
Post by steptoe » Fri Mar 29, 2013 10:23 am
yes, either max or recommended shift max, never thought what the revs might read. It is not a good idea to contnue those markers as a guide when swap up to a five speed from an L Series - I get a lot of valve bounce in second getting to the mark :D
I think hill holder is an L Series/Vortex only thing ?
Post by RSR 555 » Fri Mar 29, 2013 2:50 pm
Stretch, kind of a guide. The numbers on your speedo indicate the maximum speed you should be doing in each gear. This is subject to everything being standard, i.e. tyre, rims, driveline, etc.. The best way is to by yourself a small tacho and mount it somewhere close to eye level, so as you don't need to strain (or take too much time) to look at it. Not sure what RPMs these would be at but it's faily high, so recommend you don't try it to often on an old engine.
The 'Hill-Holder' is not available on the EA81 (M.Y.) model. It came out in the EA82 (L.Series) model and continued on throughout the EJ (Liberty, Impreza, Forester) models. You could try and fit one from the L.Series but you'd need to reposition you heater tap and make up new brake pipelines.
Post by Silverbullet » Fri Mar 29, 2013 5:50 pm
Those recommended highest gear speeds are really pushing it IMO, the closest I ever got to the number 2 mark in 2nd gear was going down a slight incline I got up to about 70...and I thought the engine was about to explode all over the road so I changed :o
Post by steptoe » Fri Mar 29, 2013 9:07 pm
Silverbullet wrote:Those recommended highest gear speeds are really pushing it IMO, the closest I ever got to the number 2 mark in 2nd gear was going down a slight incline I got up to about 70...and I thought the engine was about to explode all over the road so I changed :o
Another reason to fit your twin carb twin port engine so we can all find out - you must be bursting !
ashleyn
Post by ashleyn » Sat Mar 30, 2013 8:32 pm
steptoe wrote:Another reason to fit your twin carb twin port engine so we can all find out - you must be bursting !
My standard Brumby with Weber Carb can smash those numbers.
T.Farm.Brumby
Post by T.Farm.Brumby » Sat Mar 30, 2013 9:25 pm
ashleyn wrote:My standard Brumby with Weber Carb can smash those numbers.
Mine runs a K&N on the standard carb with a 2.25" sports setup and highflow cat and it still kills them :)
Not hard if the engine's in good condition, using good clean oil and platinums helps too, plus 98RON. I've had it as high as 85 in 2nd before, but it's not the healthiest sounding thing in the world :P Don't want to kill the old bitch so I haven't tried it again.
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'89 Brumby "Brumbylicious"
'03 Outback "Uma"
'05 Forester
Stretchomatic
Post by Stretchomatic » Sun Mar 31, 2013 12:23 pm
Haha i gave it a go just before i put the post up...80 in second and 110 in third...it did it... but i wont be doing it again haha.
Ive got a small tacho that wasnt used on another project. So when i remember to buy a mounting cup ill throw it in.
[ATTACH]4037[/ATTACH]
Had a very quick little play in the mud.
Cheers, Stretch.
Post by steptoe » Sun Mar 31, 2013 4:47 pm
I seem to recall thinking a 4 cyl sounding like these do at as little as 4800 rpm - that is sort of old Ford pre cross flow straight six redline - mine did 6000 in first `80kph, 110 in 2nd,145 3rd , 190 in top up an incline - certain the tacho read less each gear.
These things just not meant to rev unless they are the twin port twin carb beast, they don't rev like any other inline four either!
Stretchomatic
Post by Stretchomatic » Mon Apr 01, 2013 11:26 am
Thinking of changing my front drivers side cv shaft. The boot has been rooted for ages and its finally started making some interesting noises. I think the pin that holds the shaft to the transaxle might have fallen out aswell :s That would lead to rattling when you back off right?
Any special tools/tips and tricks for the change?
Cheers, Stretch.
Post by TOONGA » Mon Apr 01, 2013 12:47 pm
The noise when backing off is probably the dry CV joint (or whats left of it) rattling in its cup.
showthread.php?t=22888&highlight=shaft+change
showthread.php?t=22796
Rodeo4jake
Post by Rodeo4jake » Mon Apr 01, 2013 1:41 pm
Now that you filled it with mud it will really start to get noisy, that happened on my old Rodeo I had.
My standard, good condition EA81 hits those numbers easy too, I also tried it just the one time for laughs:).
I was driving thru Ardlethan in my truck a couple weeks back & spied ya puttin along in ya Brumby. That visor looks good in real life, has me considering one now.
Cheers Jake
Post by steptoe » Mon Apr 01, 2013 6:27 pm
How flukey was that - or do all the Brumbys in Ardlethan have the mesh verandahs :D
Stretchomatic
Post by Stretchomatic » Mon Apr 01, 2013 8:43 pm
Haha cheers Jake. Yeah its usually parked in the park parking lot across from our shop (parkparkpark). Theres a few in Ardlethan. 2 blokes have red ones and the local mechanic bought, fixed and offloaded a white targa top one recently.
I'm kinda glad the mud finished off the cv. I've had the replacement one in the shed since i bought the ute! Now i've got reason to do it. (Plus its motivated me to do some stuff to my VL incase it takes a while to replace the joint).
[ATTACH]4044[/ATTACH]
Cheers, Stretch.
Post by 60766244 » Mon Apr 01, 2013 9:25 pm
I actually wolf whistled at that picture.
Classy!
Stretchomatic
Post by Stretchomatic » Sat Apr 06, 2013 3:24 pm
Changed the cv shaft yesterday. It wasn't too bad but i still managed to fit some swearing in.
[ATTACH]4046[/ATTACH]
First up loosen your wheel nuts and the pop the split pin out of the crown nut...then loosen it. It's 36mm and mine was bloody tight, i nearly lifted the ute off the ground.
Then jack it up and take the wheel off.
[ATTACH]4048[/ATTACH]
Undo the brake caliper bolts and tie the brakes up to the spring.
[ATTACH]4049[/ATTACH]
Slide the hub off. Might take some jiggling. Then take the brake dust cover off.
[ATTACH]4050[/ATTACH]
Get a 6mm drift or punch and knock the roll pin out of the cv at the gearbox.
Then with a rubber mallet give the shaft a hit and knock it free of the bearings.
I didn't have much luck with the hub ball joint so i just popped the tie rod end ball joint out. I undid the two bolts in the sway bar looking thing and then unbolted the whole arm from the body mount.
This gave me room to pull the hub out and off the shaft. Then i yanked the shaft off of the ute and chucked it.
Putting back together was just a reverse process, just remember to gease bolts and the new axle where it slides through the hub, to help stop rust, dirt etc stuffing the threads.
Unfortunately i didn't take many pics of the reassembly because i was hurrying and geasy haha.
Cheers, Stretch.
Stretchomatic
Post by Stretchomatic » Thu Apr 18, 2013 9:09 pm
Cleaned and painted the hubs silver and cleaned a heap of mud out of the wheel arches and the rims. Got the shudder out of it!
I also ran a couple of 6mm earths off the battery. My lights dim alot when revs are low so i thought better earths might be a good start.
And a pic of the tacho i installed a few weeks back.
[ATTACH]4060[/ATTACH]
Good to see how many revs it's doing.
Might get some pics of the wiring incase anyone wants to see how they hook up.
Cheers, Stretch.
Stretchomatic
Post by Stretchomatic » Sun Apr 21, 2013 8:28 pm
I NEED MORE POWER!
Went to tumut for the weekend with a mate and cruising through the Adelong hills was a bit 'how ya goin'. Really struggled up the steep ones, think it might be time for a new exhaust and a carby rebuild!
Cheers, Stretch.
