2001 b4 liberty engine missfire
Hi People please help.
I have an 2001 b4 liberty stock car no mods, It keeps throwing the cam sensor code when i turn the a/c on and runs rough. Also on start up idles rough for a couple of seconds then runs fine , we have replace cam and crank sensors and its still doing it.
Any ideas
Thanks Dave
Any ideas
Thanks Dave
Check the ground points on the engine. The electrical load of the air con clutch could be playing funnies with the ground wire of the cam sensing
+1Gannon wrote:Check the ground points on the engine. The electrical load of the air con clutch could be playing funnies with the ground wire of the cam sensing
And also check the main engine harness doesn't have any water/moisture in them
