new subi owner with problems
Cynical
Post by Cynical » Thu Jun 22, 2006 7:22 am
ok, so i recently bought a 82 MY 4sp man dual range wagon, i've been reading these forums for tips etc an USMB for a while now, but i've run into my first big problem.
car's history, purchaded for 650, replaced starter motor, rocker cover gasket, my mechanic did he clutch, engine mounts and i think 'harmonic balancer' ?? - (getting to the edge of my mechanical knowledge on that one)
problem- car won't stay in first gear, starts to take off, then feels like i've put the clutch back in again.
is this gearbox? or clutch?? i'm hoping clutch coz thts the mechanics problem since he just replaced it.
Thanks in advance for you help.
Cynical
BaronVonChickenPants
Post by BaronVonChickenPants » Thu Jun 22, 2006 7:41 am
Does it stay in first if you hold it in place?
Jordan.
MUDRAT
Post by MUDRAT » Thu Jun 22, 2006 8:19 am
Could be your clutch is stuffed, or you've got an oil leak from your rear main seal that's causing the clutch to slip.
Monster Subaru sold to a good home!! Still a Subaru owner. Will try stay in the Ausubaru loop. Sorry :cool:
Post by steptoe » Thu Jun 22, 2006 10:39 am
detent ball springs and ball bearing area - broken spring - up in the selector area
does it flop out of gearstick position back to neutral when you are backing off the gas pedal but hold if you hold pedal down ?
Cynical
Post by Cynical » Tue Jun 27, 2006 1:07 pm
thanks for ll your help guys, turns out it was just in need of a clutch cable adjustment.
p.s i'm very keen to give this little wagon a weber and new zorst, so i'm sure i'll be posting more often when the time comes.
Cynical
SuBaRiNo
Post by SuBaRiNo » Tue Jun 27, 2006 8:00 pm
Whats your location Cynical??
Dave
Cynical
Post by Cynical » Wed Jun 28, 2006 12:39 pm
melbourne.
seems i'm one of few down here.
Return to “Trouble Shooting”
