Stretch's Brumby.
- Stretchomatic
Stretch's Brumby.
Hi I'm Stretch and this is my 85 brumby.
It was fairly tidy when u bought it, just needed a really good wash. [ATTACH]3933[/ATTACH]
In the few months I've owned it I added a sun visor and uhf roof mount antenna. ( due to it already having a hole in the roof)
[ATTACH]3934[/ATTACH][ATTACH]3935[/ATTACH]
I made a custom fascia for a head unit and amped some 6 inch speakers behind the seats.
[ATTACH]3936[/ATTACH]
And the latest was a bullbar i picked up a few weeks back. Just need to sort out some mounts so i can fit my driving lights again.
[ATTACH]3937[/ATTACH]
Other than that it's just had a service, new plugs, leads and coil and I have a carby kit for it that might help it's cold starts.
Any tips or tricks would be appreciated as it's my first subi... Cheers, Jason.
Sent from my GT-I9305 using Tapatalk 2
- uploadfromtaptalk1361150820719.jpg (84.08 KiB) Viewed 9147 times
- uploadfromtaptalk1361150700659.jpg (67.37 KiB) Viewed 9153 times
- uploadfromtaptalk1361150591218.jpg (70.83 KiB) Viewed 9150 times
- uploadfromtaptalk1361150526231.jpg (114.51 KiB) Viewed 9154 times
- uploadfromtaptalk1361150387349.jpg (68.97 KiB) Viewed 9150 times
- thunder039
welcome to the forum.
looks like a nice tidy ute!
i really like the stereo fascia you made looks very tidy and 'original'
my tip would be regular oil changes, do the gearbox and rear diff oil as usually these are forgotten, and also to keep it away from salt water and keep things out of the tub that hold moisture to prevent cancer.
2004 subaru forester -gone
1999 subaru forester- no more
1989 subaru brumby- sold!
2008 zook jimny -sold!
- Rodeo4jake
- Stretchomatic
Yeah I was extremely happy with the stereo. Normally I wont mess with the stock look, but AM radio was killing me.
Ive got a few other pics of how it came together.
[ATTACH]3938[/ATTACH]
[ATTACH]3939[/ATTACH]
- uploadfromtaptalk1361164734155.jpg (61.31 KiB) Viewed 9127 times
- uploadfromtaptalk1361164675272.jpg (49.74 KiB) Viewed 9127 times
Hi and Welcome Stretch
Nice ride mate and love the front windscreen visor.. very unique
- 60766244
Another lovely Beige Brumby.
Welcome to the forum!
Looks nice and clean being sans stickers.
I like the roof mounted aerial and sun visor!
- Stretchomatic
- 60766244
Mine is nose-down too.Stretchomatic wrote:I have a soft spot for grampa style vehicles so I couldnt resist the visor. Bloke sells them on ebay for about 180 delivered.
Thanks for the compliments.
Is it normal for the brumby to have a nose down stance or are my front springs shagged?
Maybe they're both shagged?
You could wind out the adjustable rear suspension to level it out more? I have mine slightly wound up as I usually have something heavy in the back.
- Stretchomatic
- 60766244
Underneath the car in the center (near the rear diff) you'll see a flat - 'saddle' shaped plate connected to all of that. It will have a large (19mm?) Bolt sticking out of it. If you wind it in, the back lifts, if you wind it out, the back drops. It's likely to be fairly stiff so it's best of you Jack up your rear end first.Stretchomatic wrote:I've never looked at the rear shocks close enough to see if they adjust. It did my head in when I realised they dont use springs!
Cheers, Stretch.
Ummm.. I think I'll pass.. can't really see one of them on the 22BStretchomatic wrote:I have a soft spot for grampa style vehicles so I couldnt resist the visor. Bloke sells them on ebay for about 180 delivered.
What's normal? They could be shagged but my guess would be the rear suspension is wound up and the front isn't. You can wind up both front and rear on these models. Up for 4WDing and down for everyday driving to work. Most people just leave them wound up but this does put more stress on the CV Joints.Stretchomatic wrote:Is it normal for the brumby to have a nose down stance or are my front springs shagged?
- Stretchomatic
What you mean "without the muscle" ?? it's just oozing muscles.. or is that just the driver after driving it because they didn't have power steering
Most owners wind up the back when they carry loads in the back most of the time and like you say, it's easier to do. If you wind either end up or down, try and use some good quality lubricating, I use Fluid Film as stays on there longer than things like WD40/CRC.
- Stretchomatic
- Stretchomatic
Wow.. definitely small world. Did you get the 'family discount' ?
Hey Stretch the other thing to check on the gear shifter is the selector piece on the box itself. From factory they have just a roll pin to hold it and after time, they become flogged out and make the gear shifter feel very sloppy.
I like to cut along the side of it and then put a high tensile bolt and not in were the roll pin goes, then do up as tight as possible.
- Stretchomatic
I forgot to mention that I also clean the gearbox shaft and selector, then put some 2 part epoxy on the selector before putting it back together, this just helps keep any oil out.
