Who has MY/Brumby with intermittent wipers?
- thunder039
Ok, here are the pics. Also to make a fool of me there are numbers and markings on the side that faces the strut tower - and it says intermittent relay on it too.
Totally not factory. Shit location for reduction of exposure:
Canister and wiring on either side of the strut tower:
Closer image of the spliced in wiring.
I would really like to make this look more factory but don't want to play with it when I don't understand what's been done or what needs to be done. Plus I'll run out of time with it to really sort it out.
The best I think I could do for now is get a new canister and relocated it to under the dash away from dust/moisture and heat cycles.
- Rodeo4jake
G'day
I have a September 90 model special. It has the white six pin plug under the dash, with the bridging wire as originally described. So as I understand it I would only have to get a canister & wiper switch with intermittent position & I would Have working intermittent wipers. Can anyone confirm this.
Cheers Jake
Cheers Jake
- Rodeo4jake
