L series front brake disc replacement.
After breaking the left side brake disc in half I decided to replace discs and pads on both sides. It all seemed pretty straight forward until it was time to remove the hub and disc off the axle, it won't budge. Do I need a special tool to remove the hub spacer?
Subaru GL 1800 Sedan (dark blue) 1989 In use
Subaru DL 1800 Sedan (black) 1989 RIP
Chevrolet Citation 4cyl 151cu 2500cc 1980 Given away
Lancer GLXI 1300cc 1996 Sold
Subaru Justy 1200cc 1989 Sold
It is pretty straight forward, so can I assume you have removed the large nut and 2 washers? If so, then you may find the spline a little rusty. In this case, you may need a little persuasion tool.. big f**ken hammer. Be sure to not damage the thread, best to use a brass drift in the centre.
I was wondering what that hole was for :P. Thanks I'll give it a shot. The weather conditions here are quite poor, the main reason the disc broke is sudden frost. I wouldn't be surprised if the whole thing rusted into a blob.
I'll take some tomorrow. It had been crazy wind and rain (like usual) the day before. The quick frost during the night made everything solid ice. When I was reversing out of the spot the following morning it didn't move for a second and then SNAP! broken disc.
G'day I am interested seeing pictures too - wonders how did it happen and is it common specially in cold/ice?
It could be seized due build up of dried grease, dirt and rust - happened to me once but lucky it had a thread in it and used standard bolt to pull it out, I also did on other car and I used the gear puller to get it off as well.
Gear puller sounds to me the way to go, I'm gonna check at the store tomorrow how much they cost. I'm not sure how common disc breaking is but I've broken a few pads this way in the past.
NightHawk wrote:Gear puller sounds to me the way to go, I'm gonna check at the store tomorrow how much they cost.
Theres a lot of different types depending on the size of the job. I have a toolbox full of different pullers, small mediam and large legs and 2 leg bracket or 3 leg brackets and pullers etc...
This is what I have -
I too am keen to see this broken disc. Part of me is thinking of ice that's in the vented part of the disc that's snapped it down the centre there, another part of me wonders if it's just the brake pads breaking the icy bond with the disc...
Best of luck with the swap. Time to look into a garage to keep it out of the weather?
The pulley is the best thing to use if you have one. I have one and still prefer to knock out with a hammer. When going back together, just remember to check the taper washer and make sure there isn't any grooves or lips on it, that can fol up on the hub when doing the big nut up.
I went to the store today and damn those things are expensive :O. So I did the poor man's version, put a brick under each wheel, jacked up an extra jack supporting the other axis, put the wheel back on the hub I needed removed, released the handbrake and put it in neutral, went under and kicked the wheel and spun it until it popped off
. Victory!
http://sphotos-a.ak.fbcdn.net/hphotos-a ... 8323_o.jpg
http://sphotos-d.ak.fbcdn.net/hphotos-a ... 0536_o.jpg
Here are a couple of photos.
Oooh crack just like that... ouch!
Holy crap! That's awesome and bloody frustrating at the same time!NightHawk wrote:
I hope this was an extreme event - difference in heat from one side to the other during cool down due to the hand brake holding one side of the disc?
Never seen anything like it! I hope the swap over was an easy process
- 820695_10151492654644610_1516538323_o.jpg (116.82 KiB) Viewed 6401 times
What have you guys been using to screw in the brake cylinder? I used this multi-cube thing and it started to damage the metal. It has hardly any grip and the cylinder is so damn stiff. I had to replace the pads because they chipped after the break.
Wow.. those discs are knackered
2 things come to mind whilst looking at these pics...
1) Discs look very thin
2) Looks like the pads are very high metal compound
I would buy some good quality discs and softer pads. Soft pads means more brake dust and wear out quicker but cheaper buying pads than discs all the time.
As for turning the piston back in. I make sure the resevoir cap is off (and the handbrake.. don't ask
) and using a pair of 'bull nose' pliers (opened so the nose fits in the top and bottom slot), turn them slowly back in using some force against the piston. Just make sure you leave the slots in the 6 and 12 o'clock position.
RSR 555 wrote:. Just make sure you leave the slots in the 6 and 12 o'clock position.
6 and 12 ? My brain is competing against your hands down winning experience and feels like you are playing with it - my brain - nothin' else
Those discs do look close to minimum thickness !
when I look at the new ones I have to agree. Well it's a wake up call then to put new ones in
I wasn't aware the position was important :P
