The heater tap valve thing in my coupe is leaking, a lot. I've by-passed it for now, since i certainly don't need it in Mt Isa. Wouldn't mind replacing it though.
Looking for an alternative and came accross this Commodore valve:
http://www.ebay.com.au/itm/Heater-Valve ... 7660097697
Anyone know if this would work? I'm assuming since it's 4-way pipe that it would allow flow through for the drivers side head when both opened and closed?
Obviously vacuum instead of cable operated like the Brumby one.
Cheap replacement at $20.
Brumby/Leone heater vavle replacement
- Bantum
Yeah I'd stick with original, however if the hose size is the same give it go ...
When I did mine, had to strip the dash to get to the controls & free them up, as they had rusted in place ...
Worth the trouble to fix though ..
