Is my WRX STi or not?
- Brumby Kid
You will get the "agreed value"
On my statement it has the cars details, extras and what they are roughly worth. Nominated drivers etc
And then it has an agreed value, no idea how this is worked out or how much say you get into it. This value goes down slightly all the time. (Deprechetion)
This is the value you get if it is written off.
Cheers Cam
Cheers Cam
No you still have to tell them everything, although sometimes they asume the car is standard, unless you actually tell them.'
If the car is not as per VIN and you havent told them about any mods, they can still cancel the policy.
Although from what I have seen, if the accident is minor, they do not look at your car, but they may. So its a risk if you dont tell them everything.
L serious, still.
- d_generate
Yeah you should clarify it with them but I never declared anything on mine when it was insured for fire and theft with RAC and they never asked, though I didn't make a claim either, depends who it is too because I remember when I went full comp after not having a car fully insured for over 30yrs RAC didn't want to see the car but wanted it to go over the pits and would only insure it for max 8k agreed, Just Car wanted me to take it to them for a full inspection and Shannons had a quick look and insured it for 14k @ about $560 per annum full comp and 60% NCB, so they are all different, best to shop around. Shannons assessor didn't even look at the mods when they wrote it off though it was parked in my driveway during the storm, best thing was after I beat the assessor down from $5,500 to $4,000 buy back I went out about 30min later and blew the doors off a Maserati....Twice hahahaha.
Another weird thing is I could park the Liberty anywhere at my home but I had to garage my WRX which was insured for less, luckily being a conversion you shouldn't have these restrictions.
Okay we finally got the registration paper... The engine number matches the one stamped on the block (not the proper engine number but at least it's a number) and the VIN matches as well. One very interesting thing on the rego papers is the condition that's down the bottom of the page. It says "Conditions: 302 Vehicle exempted from fitment of compliance plate."
great! sounds like the conversion has been done properly!Tomi wrote:Okay we finally got the registration paper... The engine number matches the one stamped on the block (not the proper engine number but at least it's a number) and the VIN matches as well. One very interesting thing on the rego papers is the condition that's down the bottom of the page. It says "Conditions: 302 Vehicle exempted from fitment of compliance plate."
- TOONGA
Sure does, still when Paul gets back he could look over the car to make sure it is all done correctly. (don't for get the CC's)Alex wrote:great! sounds like the conversion has been done properly!
I don't get it "(not the proper engine number but at least it's a number)" if it is the one on the back left of the block near the starter motorTomi wrote:Okay we finally got the registration paper... The engine number matches the one stamped on the block (not the proper engine number but at least it's a number) and the VIN matches as well. One very interesting thing on the rego papers is the condition that's down the bottom of the page. It says "Conditions: 302 Vehicle exempted from fitment of compliance plate."
then it is the correct engine number.
Love the last bit "Conditions: 302 Vehicle exempted from fitment of compliance plate." ... so what size engine would you like to fit?
Yeah this raises an alarm with me. Any way of checking the actual engine number on a data base to find out if the donor vehicle was stolen? This is one reason why I'd assume a secondary engine number was used - how they did this I wouldn't know.TOONGA wrote:I don't get it "(not the proper engine number but at least it's a number)" if it is the one on the back left of the block near the starter motor
Before states talked to eachother, if they actually do I'm not 100% on, but there's a story about an investigation into car rebirthing. After running through the data base of several states they found 4 or 5 V8's with the same engine number. Forensic testing on the engine block showed that the original number had been ground off and a new one stamped on from a legitimate car that was Stolen and recovered in the state that the investigation originated from...
I hope it's not the case, and if it is that it was dealt with a long time ago so you don't have another issue/hassle on your hands with this vehicle.
- d_generate
Congratulations, looks like you got a legit car with some nice mods but ...... the intake manifold from an 01/2 STI would not fit those heads as they have offset holes, I can assure you yours is a 94-96 from top to bottom, pics of my old offroader and yours.
Mine = same same
Yours = same same
02 STI, kinda sorta TOTALLY different lol.
Mine = same same
Yours = same same
From my experience, some , if not all or most states RTA data recording systems do not use a check for the correct engine number or VIN sequence - as in the system does not reject a VIN so long as 17 numbers and letters have been provided, and will take anything for an engine number. It does not use national data sheets examples provided to inspectors or online as a comparison for correct entry - as you'd expect in order to reduce errors.El_Freddo wrote: Any way of checking the actual engine number on a data base to find out if the donor vehicle was stolen? This is one reason why I'd assume a secondary engine number was used - how they did this I wouldn't know.
This error then has been carried on by er cough, an engineer doing a certificate - takes numbers off papers and not actual vehicle so the error is taken a little further down the line.
However, vigilant staff reject applications for Subarus if the engine prefix code ( EJ22, EA82 etc) ,is not included with the engine number.
All this allows for an error to say, supply the machining numbers or whatever they are on an EJ block , as an engine number and the systems will take it - just put an EJ20 in front of course to make the counter staff happy
