EA81 Electronic dizzy wiring
Just paid a mottzer to have an electronic dizzy totally rebuilt, now to transplant it .
Will need to remove the old ballast type coil & replace it- no dramas, ready to rock & roll
Question is
do we leave the two wires from the Ballast redundant or do we join them or ???????.
Also the electronic dizzy (different coloured wires to the points version) has one yellow wire & one black & white wire, I'm assumeing the BW wire is the positive?
cheers in anticipation
Question is
- Silverbullet
- Silverbullet
- Bantum
Wiring Diagram ...
I have the Electronic Dizzy in MY Brumby - it does'nt have a resistor.
Also tried to find a wiring diagram, the closest I could find was this ...
http://arrc.epnet.com/autoapp/8790/chil ... 902008.gif
Link to image may work ...
I might have a go at doing a better drawing of it later ...
- Bantum
I can't quite make out the type of coil in this ... must be a resistor type ?
But notice the dizzy + leads have been installed incorrect ( before I got it ) - I had to rotoate it 180 deg as the firing order was back to front - it still ran ok though ...
So yeah, best to check you've got it installed correctly ...
All done & dusted & thanks for the help guys. Ran the +wire that had been attached to the ballast direct to the + on the new coil. Yellow wire from the new electronic dizzy to the - on the new coil, the black & white wire to the + & boom away we went. That is until she failed, it worked out that the previous owner had installed an after market electric fuel pump which was wired into the old dizzy, anyway sorted. cheers & for our next adventure?
Another job bites the dust - in a good way. You have entered the world of no need to replace the points, or regap them, or clean them
That $300 included a new module then ? They retail for about $100 here, or $40 on ebay in the US. I am supposed to keep a spare in each ute - it's about the only thing that can cripple a Brumby
