Hope you guys are better at interpreting it then me.
Cheers Cam
Thanking you!RSR 555 wrote:"Valve Settings" is your valve/tappet clearance settings
You'll also need to check that your springs will allow for that much lift.
BTW.. I love the "Camtech Cams" for Cam
Cam,Brumby Kid wrote:Ok, cool thanks Gary.
Knowing this, what would you set the timing to?
According to what Paul says, my valve/ tappat clearance is 0.015" set hot?
Cheers Cam
Isn't the Lift at TDC (of the lobe) .227" and .232" ?littlewhiteute wrote:No valve opening/closing event points, no lift at TDC.
Set camshaft in original mark on the crank (dot on camshaft pulley to line up with chamfered hole on crank).Brumby Kid wrote:Knowing this, what would you set the timing to?
Yes that is what they want you to set them to, so I would stick to that. This will be the 'Cold' setting. This is only a difference of 0.004" Intake and 0.001" on the Exhaust. So little you'd barely notice it.Brumby Kid wrote:According to what Paul says, my valve/ tappat clearance is 0.015" set hot?
Electronic Dizzy will have 2 wires coming out of it (from memory they are balck and yellow) and the Points Dizzy will have just the 1 wire coming from it (off a spade connector).Brumby Kid wrote:What's the quick basic test for points vs electric dizzy?
No, that's maximum lift at the cam lobe.RSR 555 wrote:Isn't the Lift at TDC (of the lobe) .227" and .232" ?
So my 0.015" is 15 thou... Are you suggesting that this is too big or small?steptoe wrote:On valve settings - that 15 thou hurts my ears ! 15 thou hot !! man, 12 thou cold was bad enough !! In the end I did them my way ...4 thou hot both and that was a start up warm up again between either each cylinder or each bank, though run the risk of things getting tight and maybe a miss if let its temps get higher than half way on water temp gauge
15 thou hot would be waaay to big. I think 15 thou would be the cold setting. 1 thousandth of an inch is .025mm so 15 thou is nearly .4mm and if there was this much clearance at operating temp you'd have one hell of a racket!Brumby Kid wrote:So my 0.015" is 15 thou... Are you suggesting that this is too big or small?
I do get a bit of a lifter/ rocker tap but just assumed this was normal.
Might play around with the clearances if you think I could go better, however the cam grinder did know the specs of the engine so would assume he could work out what was best
Cheers Cam
Oh shush you! I have a fancy calculator and deal with shares, investments, homeloans, and stats hahahasteptoe wrote:so yeah kid in school that should be still fresh on fractions I reckon 15/1000 is a bit on the big gap side.
