MY Wagon suspension options
- GunFactory
About to sort out refreshed suspension in the MY
What are the pros and cons of something like this? Am i better off with plain old springs?
http://www.ebay.com.au/itm/Subaru-Leone ... 500wt_1219
Pump up shocks transfer the weight from the springs to the shock mounts, which they are not designed for.
From experience they are "bouncy".
If neither of the above worry you, they are a cheap way of putting more weight in the back of your vehicle or lifting your vehicle.
If you puts lots of air in with no weight, they lift, but ride very very hard, loosing wheel travel.
So they have good and bad points.
- GunFactory
Cheers tam box
Im not sure on them, There are some good looking other options..
For example these are only marginaly more expensive than the 'ultima' alternative
http://www.ebay.com.au/itm/140753790231 ... 1060wt_986
I dont like the idea of bouncyness or stressed mounts.. really I'm looking to increase the 'street' handling of the car (speed bumps, roundabouts and potholes) as well as feeling confident im not just going to pound the bump stops on the first dirt road/track I hit...
So - Thoughts are
- Near new strut inserts
- New front springs
- Undecided on solution for the rear yet - seeking tips!
So - Thoughts are
- New front springs
- GunFactory
Dad used to have them in his Kingswood and I've been looking for a set to use in the L series but these one's won't work as I can't fit a spring around them
If you're not sure about them go with the KYB gas strut (aftermarket), I've got a set on the rear of my L series and they go great so far. You should be able to get a better price than that though!
And springs - well, I always have a bit of a cringe when people say they need new springs, half the time they really do, the other half they just need a good set of new shocks in there to reduce the bounce
- GunFactory
