WRX Rear LSD
hydrowill
Post by hydrowill » Mon Nov 05, 2012 7:10 am
Here are some pics. Sounds like you guys are on the money tho.
Best thing about the diff is that it is a 4.111 ratio.
Post by El_Freddo » Tue Nov 06, 2012 8:25 pm
Well, I've got no idea with those pics, it certainly looks like an open diff :(
How do you know it's a 4.11? Just curious to know that you've got it right ;)
Still got friction when you turn one output stub and hold the pinion shaft?
Post by Gannon » Tue Nov 06, 2012 9:34 pm
Later lsd's look the same as an open diff because the viscous coupling is between the side gear and the crown wheel. Turn the 2 output shafts against each other. If you can easily turn them in opposite directions, its an open diff.
hydrowill
Post by hydrowill » Wed Nov 07, 2012 9:54 am
Hey Bennie, It has 37:9 printed on the crown wheel so my calculations say 4.111?
Yeah if you hold the stub and pinion shaft it is really hard to turn and there is a lot of resistance. The the other stub turns in the same direction. It is an lsd without a doubt.
Stoked to have got it for 90 bux ;)
Post by El_Freddo » Sun Nov 11, 2012 12:00 pm
hydrowill wrote:It is an lsd without a doubt.
That's awesome!
If that's printed on the crown wheel I guess it's correct then - this relates to the number of teeth on the crown and pinion gears. This will mean that the pinion shaft will have 9 teeth ;)
