brumby starting issue
thunder039
Post by thunder039 » Tue Sep 25, 2012 8:37 pm
TOONGA wrote:
When I'm not looking after children or driving 240km in a round trip for work, I will find this mystery relay in my 89 brumby.
im looking forward to finding out ;)
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
thunder039
Post by thunder039 » Tue Sep 25, 2012 8:47 pm
not sure if the 87 brumby is the same as the 89 but i found this which helps with our answer
http://www.answerbag.com/q_view/743527
what cant google find :?:
Post by TOONGA » Tue Sep 25, 2012 8:53 pm
LOL I just read that and was going to post it:)
GOOGLE will assimilate us all
when I get a chance I will look for it :)
Check ...
Post by Bantum » Wed Sep 26, 2012 2:28 pm
thunder039 wrote: 1. no need to rip up my floor vinal to check the relay unit?
2. there is no relays for the fuel pump?
3. therefore the only things it could be is a block, a stuffed pump or a fuse?
1. not unless you want to ... :neutral:
2. definitely, cut of switch yes - no relays ... :D
3. all possible, you just need to go through the elimination process ... ;)
Post by TOONGA » Wed Sep 26, 2012 4:01 pm
You may want to check the fuel line as well, it could be full of 20+ years of tank sludge
thunder039
Post by thunder039 » Wed Sep 26, 2012 7:08 pm
finally got a chance to look at the car today.
first off checked the fuse= good
so i went to strait to the fuel pump.
i blew air down the fuel lines that headed from the pump to the engine still no go.
the fuel pump does pump i can hear it, but no fuel is coming out of the pump :(
the filter before the pump has fuel and isn't blocked (fills up when emptied)
so could the pump still be stuffed even though i can hear and feel it pumping?
littlewhiteute
Post by littlewhiteute » Wed Sep 26, 2012 7:22 pm
Does it pump with the fuel cap off?
Gary ;)
thunder039
Post by thunder039 » Wed Sep 26, 2012 7:33 pm
nope
Post by steptoe » Thu Sep 27, 2012 8:36 am
try blow through the pump- to- tank line ?
If your needle and seat is stuck on float bowl is full position you can be tricked into thinking fuel pump is no good. I was tricked once, and had to buy a new pump that still left me stranded outside the Ford dealer. Ford had to be towed home by a Holden :( until I found the Holley anti splash guard for bowl vent hole (crude eh?) on the 465 four barrel was fitted to the wrong side of the retainer gasket,(by me ! :( ) subsequently fel into the float bowl, sloshed around on the bottom and occasionally would jamb its wedge shape under the float as I went up inclines, like the one outside the Ford dealer
thunder039
Post by thunder039 » Thu Sep 27, 2012 8:40 am
ill try blowing air through the pump today hopefully
Test ...
Post by Bantum » Thu Sep 27, 2012 2:31 pm
thunder039 wrote: ... so I went to strait to the fuel pump ...
... could the pump still be stuffed even though I can hear and feel it pumping ? ...
I'd remove the pump ( clean & inspect while your at it ) & do a 'bench' test with a suitable tank etc, to see if works correctly ... :wink:
thunder039
Post by thunder039 » Thu Sep 27, 2012 3:55 pm
SHE LIVES!
well i went and just replaced the fuel pump with a spare pump on my parts
brumby which luckily worked so its all good now im thankfull it was just the pump
Post by TOONGA » Thu Sep 27, 2012 4:26 pm
Well done good to see it wasn't the fuel cut relay :)
So I have had time to look for this elusive box of tricks that doesn't exist. :)
instead of breaking my neck I got my trusty camera to do the hard work nope not there.
anyone have any idea what those 2 relays do? I turned my hazard lights on the flasher relay clicked but not either of them.
Hmm I wonder if I pull the change holder where I can hear the the indicator relay can it be accessed ... wait WTF thats not the flasher unit ... ZOMFG thats it the elusive fuel cut relay
and whats that next to it ... it was still clicking when I took these photos
you can see the flasher unit (sort of) next to the fuel cut relay.
and read here for my little brumby won't start saga
Nope not there ...
Post by Bantum » Thu Sep 27, 2012 6:58 pm
TOONGA wrote: ... So I have had time to look for this elusive box of tricks that doesn't exist ...
Correct - dosen't exist ... :shock:
TOONGA wrote: ... anyone have any idea what those 2 relays do ? ...
They are headlamp relays ... Items 29 + 30 ( going by wire colours )
TOONGA wrote: ... wait WTF thats not the flasher unit ... ZOMFG thats it the elusive fuel cut relay ...
Umm - No it's not ... It's Item number 16 on wiring diagram ... Intermittant wiper control unit ... :p
P.S - That wiring diagram I refered to is pretty close to what every Brumby has, as posted elsewhere - When they made them in the factory, they used the same loom in just about every other MY model - So don't go reading too much into it, just ignore the bits that don't belong to the Brumby ... :)
Post by TOONGA » Thu Sep 27, 2012 7:07 pm
Bantum wrote:Correct - dosen't exist ... :shock:
ha ha :)
Bantum wrote: They are headlamp relays ... Items 29 + 30 ( going by wire colours )
ah ok
Bantum wrote: Umm - No it's not ... It's Item number 16 on wiring diagram ... Intermittant wiper control unit ... :p
That would be correct if the car was a 1982 -4 wagon or American delivered Brat :)
Wire Trace ...
Post by Bantum » Thu Sep 27, 2012 7:18 pm
TOONGA wrote: ... That would be correct if the car was a 1982 -4 wagon or American delivered Brat ...
To make sure - Find out where the wires go + what colours they are ...
Then see if they match the wiring diragram ... :)
Post by TOONGA » Thu Sep 27, 2012 7:30 pm
My brumby doesn't have factory intermittent wipers, no AU delivered brumby ever did.
It is the fuel cut relay I was talking about.
Do you have the correct wiring diagram for the 1989 Australian delivered brumby?
the only one I know of, is in Perth and the owner is currently driving oil rigs.
thunder039
Post by thunder039 » Thu Sep 27, 2012 7:55 pm
TOONGA wrote:Well done good to see it wasn't the fuel cut relay :)
so was i :grin:
Post by steptoe » Thu Sep 27, 2012 9:15 pm
another phew as those cut out relays are about the 4 hunge mark or more exJapan.
Those relays side by side are the common old 22A Mitsu Fuji used almost everywhere for generations in our Subes as ignition, fuel and light relays. think those two are left and right configured.
The old shove-the-camera-in-the-hard-to-see-location is great eh ?
Thunder - make sure you toss the crapped out pump so it don't end up as a maybe it was a good one in a few years time.....
These pumps are cheap enough to have a spare rigged up for emergency repair diagnostics. Bit like having a spare coil mounted under the bonnet, spare module in the glovebox .....
thunder039
Post by thunder039 » Thu Sep 27, 2012 9:22 pm
steptoe wrote:another phew as those cut out relays are about the 4 hunge mark or more exJapan.
phew lucky then ;)
yeo went straight in the skip bin :D
Return to “Trouble Shooting”
