83 MY wagon in my sights
LOL
See what I am up against.
If the hole aint big enough it is the position of the repair.
Anything is possible though.
Gave her a scrub, degrease and oil change today.
I do want to fix her up to register it.
- IMG_1327.jpg (102.37 KiB) Viewed 4089 times
- IMG_1326.jpg (97.87 KiB) Viewed 4088 times
Looks like you have some practically new tyres on it
yep from what I understand less than 5000ks.Gannon wrote:Looks like you have some practically new tyres on it
just discovered it has newish flexable brake line on the front too.
The motor runs incrediably well, it is rocker noisy but I can adjust the valve clearances eaily.
Getting so hard to see the old girls on the road these days, it would be sad to see it parted
I vote to keep her alive
once had a Valiant in the family that came from a concreter, and that concreter brought some master repair skills with him from the old country for rust holes like that. Started with a stuffing of newspaper then some left over - er ???? slab/driveway/footpath
Had to be seen to be believed with the finish !
Thats nothing, my father in law once used bread, plasticine and masking tape to patch a rust hole the size of ya fist. The funniest part was that it actually fooled the rego inspector and passed with flying colours.
I can use metal so will go to the extra trouble to weld some in.
run some radiator flush through it today for about an hr.
OH boy did that flush out some crap, then back flushed the radiator and even more crap came out.
I am sooo butsing to do some work on "Wanda" but I got a heap of projects to finish off before she gets some TLC.
Glad to see someone's picking up on the rust holes!Gannon wrote:Looks like you have some practically new tyres on it
I know how that feels! And I'm sure if it's not other projects, it's work or something!revmax wrote:I am sooo butsing to do some work on "Wanda" but I got a heap of projects to finish off before she gets some TLC.
yer work always gets in the road of having fun.
My latest is putting a full 3mm alloy checkerplate floor in the trailer, might get that done over the weekend though.
Well we got the alloy checkerplate floor fitted into the trailer. SO Wanda will get some lovin tomorrow.
shouted myself a toolex blast pot.
https://www.gasweld.com.au/products/592541 I am very impressed.
and gave it a test run today, it seems to use less air for the same result as my little baster.
I have a full day of blasting cutting and welding planned for Wanda tomorrow.
She is already up on ramps with stands in place. blast pot filled and tools at the ready.
My air supply is a 15cfm Stanley and 17cfm Toolex compressores in paralell with an extra 50L tank situated right beside the blast pot. This is so if there are any losses in the long lines cause the compressers are in my shed, the extra tank will act as a header or balast.
- Silverbullet
RDO, only get one a month and the neighbour will be at her work so i can make some noise.
Gunna wreck it.
- Brumby Kid
What parts does she have?
it is a complete running car, coupla parts reserved for my brumby though
http://www.gumtree.com.au/s-ad/coffs-ha ... 1005317029
- Silverbullet
dash is spit to bits. Yer the door trims apper in good nick
I will put an add in the propper section so I dont clog up this forum.
