brumby gearbox oil
thunder039
brumby gearbox oil
Post by thunder039 » Tue Jun 12, 2012 3:30 pm
as the title states i am after some advice on gearbox oil for my standard brumby, its original gearbox with 266ks
was wondering what the reccomendations are without spending a small fortune and how much i need in terms of literage
thanks!
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
alang
Post by alang » Tue Jun 12, 2012 7:25 pm
A SAE 80W-90 oil and 3.0 ltrs
thunder039
Post by thunder039 » Wed Jun 13, 2012 5:20 pm
alang wrote:A SAE 80W-90 oil and 3.0 ltrs
thanks!
Post by steptoe » Wed Jun 13, 2012 7:28 pm
and if I was you , try get some of Nulons additive for rejuvenating oil seals to soften the front seal especially. There is a specific additive and it is not G70
thunder039
Post by thunder039 » Wed Jun 13, 2012 7:36 pm
steptoe wrote:and if I was you , try get some of Nulons additive for rejuvenating oil seals to soften the front seal especially. There is a specific additive and it is not G70
is this the gearbox conditioning stuff?
alang
Post by alang » Wed Jun 13, 2012 9:21 pm
they stopped making it they only have the G70 or their blend of gear oils with additives.
even wynns use to make a good one, don't any more not here any ways
still be using the G70 but :p
Post by El_Freddo » Wed Jun 13, 2012 9:32 pm
I'd just drop some standard gearbox oil in it, there's no point spending more money than you need to, it's not a high performance gearbox after all.
Or you could go for a LSD grade oil, I did this with my box and found that it's changed smoother since. The fellas at my local parts joint know I 4wd and reckoned it was going to be a better oil for the heat that can be generated in the slow stuff. From memory it was another couple of dollars but in my book worth it!
revmax
Post by revmax » Thu Jun 14, 2012 6:20 am
Post by steptoe » Thu Jun 14, 2012 9:24 am
Just off the phone Nulon techos - the Nulon additive is ESL, short for engine stop leak - add 60ml of ESL per litre of oil capacity of manual gearbox only. The chemistry lends the technology of auto tranny fluid of keping all their seals and O rings supple.
thunder039
Post by thunder039 » Thu Jun 14, 2012 9:49 am
thanks guys for the suggestion i will go to repco and have a look at the oils for comparison
bennie i dont think i need the lsd oil as i very rarely 4wd in the brumby and most of its time is spent at 100kmh but thanks for the suggestion!
alang
Post by alang » Thu Jun 14, 2012 1:14 pm
steptoe wrote:Just off the phone Nulon techos - the Nulon additive is ESL, short for engine stop leak - add 60ml of ESL per litre of oil capacity of manual gearbox only. The chemistry lends the technology of auto tranny fluid of keping all their seals and O rings supple.
that's good to know, have to have a look for it next time doing the oil changes :D:D
