And , if you have a spare fuse box to pull the spade terminals from, there is usually a spare hole or two in your L's fuse panel to insert from behind in a battery or IGN supplied section to fit a fuse in for accessories you have installed.
L series spot lights
System error I D 10 TCliff R wrote:Idiot alert...idiot alert.
I have just spent the last 2 hours trying to get the spot lights working but no good.
Why ?
I have not proven it yet but IT BLOODY WELL HELPS if the main feed directly from the battery is CONNECTED !!!!
Bahahahah
You gotta laugh dont you.
it happens on many an occasion especially late in the arvo.
Hylton
I can't remember how I did it last time, but the way I've got it now doesn't work properly - when the stock lights are off the auxiliary lights are on. But they work as they should when the stock lights are on. Just need to swap the power source for the cab switch from the parkers, which are positively switched, not earth switched like the rest of the L series.Gannon wrote:What other way is there to do it?
I think the parkers are the other way around so that they can be left on with the steering column switch when the ignition is off - for ADR's/other country's regulations.
