after Gannon's suggestion , got it, made a nice little backing plate, glued it into the clock surround, hard wired it into the car using a clip connector to use the clocks power and earth, added the signal wire from diagnostic connector near dizzy to blank connector terminal slot - to read the normal operating 1.7Volts or if knock sensor unit cutting in will read 4.5Volts.
Reads -0.4Volts when running engine @ idle , tap into it with my multimeter, DMM reads the needed. expected 1.69 Volts.
I have checked specs prior to purchase - runs on 12V, reads from 0 to 50V
I am only using Volt read circuit so eliminated two wires. and using instrucions - Run off the meter with separate power supply.
The instructions are in black and white, do not name colours of wires but give diagram showing the shades of grey that colours have and the back plug.
GREEN is to pos 12V separate power supply + at the clock plug
WHITE goes to sep.power supply neg - at the clock plug
next two wires, YELLOW and BLACK involve a current shunt, a load, and a switch - AMPS hook up I gather- remain disconnected.
last wire RED goes to my test wire.
Something is wrong. Have emailed lightning boy 2008
any ideas gents ? and kid
Righto, hooked up the Volt meter sensor wire to a known flattish SLA battery ~ 8.5 Volts - positive to sensor, negative of test battery to car ground , turned Volt meter on - got 6.5V
Next, hooked up a brand new heavy duty alkaline AA battery from Dicka Smith , DMM says it has 1.6Volts, Lightningboys unit -0.04 Volts !
Then the test lead goes to cars battery of 12.something volts unit reads 10.something, give a few revs and she goes up a few volts but not the charging 14V she was showing on the temporary panel meter. I'd suggest the accuracy of this unit is not as specified - more like out by one point two Volts..... at the lower end of the scale
Something to put to lightningboy2008 !
Lifted from the ebay site ....Accuracy: 0.2%±1 word
