Leone RX suspension lowering
Nope, 7249 spring for both FWD sedan and 4WD wagon, both with 8201 strut, shock for 84 -87 model wagons, later 87 - 94 wagons used different shock , #8202
Can that idea until you find a FWD sedans rear coil that is not same as the wagon
might be repeating self here with :
Pedders numbers and their measures
#8201 Pedders is 154mm, #8202 is 130mm, #8203 is 142mm
Upon closer inspection, the springs had a pink and orange daub of paint on them
Apologies for the crappy phone and torch photo
- 2012-06-03 22.05.44.jpg (95.42 KiB) Viewed 5019 times
So RX springs in wagon struts will provide the same height as RX springs in RX struts?
What if I were to find a 4wd Royale sedan, where does it sit in this equation?
Royale sedan is FWD sedan, so likely same as any FWD rear coils, sit same as RX rear springs but softer by 20 lbs ? is my guess....they were gonna be my first try but the RX springs turned up, one by one . I'm not saying if the RX rear springs on wagon struts will do the job, if your wagon struts specs match the pics I sent you - good bet anyway
Mmmmm, I'll hit Nev's dad up, he has a collection of springs in his shed
Ok I have just summarised some info from this thread, please correct me if any of it is incorrect
There are 3 different spring rates... which should correspond to 3 different spring thicknesses
160in/lb for FWD sedan..... 9.9mm thick
180in/lb for 4WD RX......... 10.5mm thick
197in/lb for 4WD wagon.... ?mm thick
There are 3 different spring lengths
130mm, 142mm and 154mm but both FWD and 4WD RX have same unsprung length, but 4WD wagon has a longer unsprung length, so that means there is another model in the mix
There are 3 different strut lengths (bottom mount to bottom of spring seat, so has no effect on spring tension)
130mm for 4WD wagon
150mm for ?
170mm for ?
So....... If I use FWD rear springs in wagon struts, im likely to get a soft ride with a marginly lower than standard RX rear (due to lower spring rate). If I shorten wagon springs to the length of sedan springs, I will get a very firm ride, marginly higher than a stock RX but likely too bouncy?
Id be happy with the former, as it appears my front with my standard EJ22 Liberty struts and springs gives very close to standard ride height, if need be I can try WRX or even standard Impreza springs to lower it a little more.
130mm for 4WD wagon
150mm for ?
170mm for ?
Gannon, did you confirm you have the 130mm shocks? I dont know if the wheel-wells are different on the L sedans compared to the XT's but maybe you can flip the top shock mount? On the XT's you definately can't opposed to popular forum opinion, but maybe in the L's you can...
Another thing that can be done is aftermarket coil-over sleeves and springs, so you can adjust them, I dont know how your chosen engineer would feel about them though...
# EA82 AWD 4EAT,
If you have them please PM me
# EA82 AWD 4EAT,
Ive seen a photo of a flipped top mount in a wagon, but it involved cutting a piece of metal out of the body above it to accommodate the nut on the top of the shock
I have not yet confirmed the strut length I have. Will be the next thing I do
I think it might be more than the nut aye, its more the large diameter rubber bush and its keeper that gets in the way...
# EA82 AWD 4EAT,
# EA82 AWD 4EAT,
I'll give you message too short ........Gannon wrote:please correct me if any of it is incorrect
There are 3 different spring ??? tired lad - imagine coils 130 to 154mm tall
lengths
I think the RX yellow blob coil was 310mm high unrestrained
130mm for 4WD wagon
150mm for ?
170mm for ?
Subaru had three sizes, and Mr SomeBull has three sizes, other brands ~ KYB had 129mm
So....... If I use FWD rear springs in wagon struts, im likely to get a soft ride with a marginly lower than standard RX rear (due to lower spring rate). If I shorten wagon springs to the length of sedan springs, I will get a very firm ride, marginly higher than a stock RX but likely too bouncy? I tried cutting wagon springs for my Vortex, then they were loose and still not achieved desired resulting height
I had to read it a few times but now I get where I made a boo boo. Yeah they would be rather stout at only 130mm.
Problem is that the RX is 35kms on a dirt road away and the last 2 times I was there was after dark.Have I missed something ? like measure the strut from spring base to its max reach as well as spring base to bottom mount hole ????
Ok i have been taken some measurements and some photos.
Bottom mount to bottom of spring seat- 125mm
Top of top spring mount to bottom of bottom spring mount - 260mm
Ill upload some photos shortly
Its possible they werent measured center of eye Jonno;)
# EA82 AWD 4EAT,
# EA82 AWD 4EAT,
- Brumby Kid
Haven't been following real closely. I understand why your doing but why?
Why are your springs/ struts at different heights?
Don't you have 4 struts the same size?
Cheers Cam
Cheers Cam
