As the title says I have a 1990 ea81 Brumby the problem is I'm looking for a fuel line layout from the external fuel pump at that rear which goes to the filter Z366 I think then up to the engine compartment. this is where I am getting confused at present there is another fuel filter there as well, a ryco Z428 which has 3 ports, at one end it has a single 7mm port which is hooked up to a line that heads back into the firewall about in the centre of the engine bay(over pressure pipe I assume)
. The other end of the filter has 2x 8mm ports the one with the arrow marked on it goes off to the carby and the other is the line that comes from the fuel pump(tested by turning ignition on with pipe disconnected).Does this seem right as I would have thought the input from the pump would have been the end with the single port, Gregory's manual a waste of time hoping someone may have manufactures workshop manual which explained it better, diagrams would be a great help.
