Update on my Brumby
- FROG
How does this one look fellas?:D
- FROG
Pm sent
- TOONGA
Update time again
and a short story... get a cup of coffee and some cake ready
for the last week or so I've had what I thought was a carby problem, under acceleration the engine would stall when the second barrel opened with a big gluuuuuuuurrrrrrrrrrrrrrrrrg, then when I took my foot off the pedal I would get power again.
So on Friday morning I was set to remove the 32/36 weber for a rebuild and use my 34 ADM while I did this. I put my daughter to bed (monitor in place so if she woke I would hear her)
I got the car into the garage and it wouldn't idle, it stalled so I got out got it going and gave the engine a rev. it was fine until the second barrel opened then glurrrrrrrrrrrg pop fizzle stall ... no restart, nothing but the flooded smell associated with a drowned engine. I pulled the lead for number 1 and placed a spark plug in the lead and placed it where it was earthed and I could see it no spark... uh oh out comes the test meter.
After testing everything I could, I decided to pull the dizzy and test the igniter and internal winding. The igniter was fine, the winding I wasn't too sure about I would get a reading then it would disappear. I noticed also that one of the brass poles in the cap had a wear mark from the rotor button.
Break out the new dizzy and coil whoooo hooooo ... Meme wakes up
boo hoo hoo
Packed my tools away as quickly as I could, then went to free my daughter from the bedroom. (left PJ in the garage overnight)
Saturday morning - the first thing I had to do was wire the new dizzy correctly as for now I don't have a spare module. so I set everything up and put all the wires in their correct places ... SPARK from the coil ... a big fat hurty spark (do the happy dance?)
I found top dead centre lined the dizzy up for number 1, then the fun began the cap has screws not clips so I had to screw the cap back into place and then put the leads on. (what was that firing order again 4512 3178 1342 no wait 1324)
First start vroo..pop pop pop vrooo pop pop pop idle pop idle pop splutter stall.
So I swapped the leads for 2 and 4 at the plugs, thinking I had mixed them up. then I tried to start lots of backfiring no start, I put 2 and 4 back. then went to 1 and 3 and swapped them at the plugs, no start lots of backfiring with 3 foot flames ... mmmmmmmm warm ...mmmmmm loud .
still no joy and I was back to vroo..pop pop pop vrooo pop pop pop idle pop idle pop splutter stall.
Now I had a choice start moving leads on the cap or try starting the engine with 2 leads removed as the leads on the engine are easier to get to I removed 3 and 2 not for any real reason but because I was sure I had number 1 right.
I tried to start pop pop pop ... pop pop pop... SIGH.
I put leads 3 and 2 back on and swapped 1 and 4 at the cap and finally PJ starts. once the unburnt fuel cleared and the engine warmed up I timed to 8 degrees and went for a drive. there was no ping but acceleration was a little sluggish but she was running fine. back to the timing light and I set the timing at about 14 degrees (hard to tell with the marks) and I went for another drive ... no ping great acceleration FANTASTIC.
Test drive time I went and got fuel, as I was nearly empty by this time. Once I had fuel it was time to see how PJ was going. I stuck my foot into first gear and the engine revved quite happily to 4000 rpm (never did this with the old dizzy) the same with second and I hit 90 something KM/H before I changed into 3rd without a hitch. Next I went to my off road test track and loaded the engine up in first in the soft wet sand and drove right out of a set of canyonaro ruts like they weren't there.
Needless to say the car is running really well and my carby was never blocked (even if it was I'm pretty sure anything that was in the carby is now on the garage ceiling)
I will try to get pictures Later today as wifey has gone shopping and I'm babysitting.
now I need a coffee after typing this
nice new coil
Dizzy hiding under wires and power steering lines
Dizzy from another angle
My personal favourite the gap between the steering knuckle and the dizzy
nice new coil
Those parts look mighty familiar Jules
Giles.
Giles.
Awesome.. now that dizzy looks better in there than the MKIII one
- TOONGA
the old coil (bog stock brumby coil) was the wrong one for the dizzy, the module on the MKIII was a generic bosch igniter (which is why the winding was on the fritz) I've found one on a triton motor at the wreckers but I don't think I would be that lucky finding one for my new dizzy here in Australia.steptoe wrote:Was thinking coil as I started to read the latest entry , was same problem with mine recently - the EA82T continues to rip
Yep thanks again Giles I would definitely recommend this dizzy and coil setup to anyone wanting to carby an EJ. (Giles I may even send you a link yet for a module for the new dizzy1111giles wrote:Those parts look mighty familiar Jules
Yep not only does it fit better it runs better and is way more accurate when being timed.RSR 555 wrote:Awesome.. now that dizzy looks better in there than the MKIII one
The only issues I've had are the rubber seal on the base of the dizzy and the key for the cam, the brand new seal was smaller than the one on the MK III dizzy. when I came back from a drive and parked the car a small pool of oil formed under the dizzy. this was fixed by putting a thicker seal in place.
As for the key on the base of the dizzy it needs to be pressed off if I want to use the one from the MK III.(was machined to allow for the 2-2.5 mm of height difference) for now the dizzy is sitting on a 2.5mm flat aluminium washer so it sits flat when it is tightened up.
- TOONGA
just a little update on PJ
I got talking to a guy who had a 2 litre hilux with a weber on it. in the course of discussion we got to talking about the primary and secondary main jets and the idle Jets we used. he is using 132 primary and 130 secondary mains with 50 idle and 55 secondary idle while I was using 135 primary and 145 secondary and 55 idle and 55 secondary idle.
Ive since changed my idle jets to 50 for the primary and kept the 55 for the secondary and changed my secondary main to a 130 and kept the primary at 135
will see how the economy fairs now
- TOONGA
Well the economy is a bit better around 9lt/100km on the highway and 10lt/100km around town (and in the negatives on the beach
I finally changed the key on the end of my dizzy Yesterday and now it bolts up without needing a spacer and suprise suprise it worked first time even though PJ sat for nearly 2 weeks without being started.
at least one of my cars is running really well
- TOONGA
with all of the water/methanol injection talk going on, I decided to try the low pressure injection method.
My 34ADM has a vacuum port that comes out under the primary butterfly, so what better point to start. (after I went shopping that is)
A quick trip to the aquarium shop and for less that 8 dollars my kit
2 air stones 2 air taps and 5m of air hose $7.30
(the left overs actually)
The setup (note the full washer bottle)
Has it made any difference?
on Saturday I rebuilt my carby, due to a cracked body that was causing a major air leak.(the good doctor Urabus confirmed I had a strange air leak)
see if you can spot the crack
Once I had the carby rebuilt and running. I had to drop my timing from 15 degrees to 10. with the water/metho I can run the car at 15 degrees again.
Won't know about economy until I have gone for a drive this weekend.
Bottom right corner where the bolt hole is?TOONGA wrote:see if you can spot the crack
I'll be keen to know what it is. I wonder how a kit like this would go on an EFI system - could be handy in the heat of summer on the sand. But I can't be bothered finding out how it will effect the EFI system (extra oxygen in the exhaust?).TOONGA wrote:Once I had the carby rebuilt and running. I had to drop my timing from 15 degrees to 10. with the water/metho I can run the car at 15 degrees again.
