1) I dont know the correct way to lock out the hill hold brake valve ?
2) I can not get the manual shift to work on the auto shifter
3) when brake is on the lights go out on the shifter
4) steering very heavy , need to bleed the pump ?
I need to sort the above before I can come & play
I ran the liberty down the road going to have to make it quiet ( but man does it go FAST )
Just about done But !
3) it will more than likely be a bad earth. There will be a common earth some where under the dash for both brake and shifter lights, clean and reconnect this earth.
"Claudia"
"Claudia"
