Brumby Trailer
revmax
Brumby Trailer. ( Can some one move this thread to the build section please)
Post by revmax » Mon Feb 27, 2012 2:52 pm
Anyone choped a Brumby in half and made a trailer from the back half.
I have an Idea and half a brumby but would like to see if anyone else has done it.
purp
Post by purp » Mon Feb 27, 2012 3:07 pm
I know that an L series trailer has been done. Don't know about a Brumby. It would actually be easier, what with the try already designed for load carrying.
niterida
Post by niterida » Mon Feb 27, 2012 6:19 pm
Now thats a brilliant idea - I might have to do that with my wrecked Brumby :)
Someone get busy with photoshop......................
d_generate
Post by d_generate » Mon Feb 27, 2012 6:48 pm
Here ya goes, took me ages lol.
revmax
Post by revmax » Mon Feb 27, 2012 6:49 pm
found this googling.
But I am more interested in chazie rail to draw bar attacment details.
revmax
Post by revmax » Mon Feb 27, 2012 6:59 pm
I Have this A coup rear suspension and some bits n pieces I have acumulated.
It has some rust so I will have to blast it in places.
IMG_0386 800.jpg (85.64 KiB) Viewed 4480 times
Post by steptoe » Tue Feb 28, 2012 8:38 am
Your missus gonna kill you ?
:D grafiti dudes been at your trailer plate too !
You are thinking what ? torsion bar instead of leafs ? The Brumby only had 20mm bump stop clearance - consider that with your trailer idea. Should be a quick job
1111giles
Post by 1111giles » Tue Feb 28, 2012 10:26 am
Personally I would keep using the white trailer you got the half cut on !
Having made trailers of all types here in the UK the finished product will allways be a compromise of one sort or another.
The main area of concern should be the design and application of the A frame or draw bar. Get this wrong and the thing wont tow correctly or could be inherintly weak and thus a danger. There should be extra depth in materials where the draw bar / A frame appears from under the body of the trailer. Have you considered the method of braking and actuation of same ? (in UK hydraulic brakes on a separate trailer are not permitted) The cab back also will make for disruptive aero dynamics at speed.
Payload ? 400kgs in the Brumby as a vehicle - what can your tow vehicle tow - remember its the combined gross maximum that is the figure to establish / see if you can legally tow this / braked or un- braked.
It can be a minefield !
Great if you want a 'looker / project' but not an ideal base for a work-a-day unit.
Giles.
Post by guyph_01 » Tue Feb 28, 2012 11:51 am
1111giles wrote:Personally I would keep using the white trailer you got the half cut on !
What a project mood killer...., lol. But i guess you have some good points.
I would love to make one too one day:) I remember that there is a guys that used the brumby torsion bar/axels to build a custom tilt trailer over east.... Not sure who.
revmax
Post by revmax » Tue Feb 28, 2012 12:41 pm
Steptoe. yer she is not real excited.
Yer Torsion bar, I have a setup from a coup.
thanks for the 20mm heads up, i'll keep that in consideration.
Gilies. I am keeping the white trailer.
see post no 5. this is my main concern also.
No brakes and it won't be aerodynamic as it will be a "looker" project. I don't even plan on keeping it but want to build one. (cause I can)
Guy, I had already thought of the things Gilies had mentioned so he hasen't put my flame out yet and appreciate his and your input.
I have an idea, just need someone to help me get the shell off the trailer, but I have to roll an L series onto its roof to stip some parts off before I start on the trailer.
Keep the ideas coming fellas
revmax
Post by revmax » Tue Feb 28, 2012 2:20 pm
Steptoe I just checked the Brumby swing arm has 25-30mm bump stop blocks on th arms where the coup doesen't have any blocks. At a guess that will give and extra 50-60mm travel at the axle before the swing arm hits the rubber. I may have to weld a 6mm flat plate on the swing arm though to the rubber stopper hits a flat surface.
revmax
Post by revmax » Thu Mar 01, 2012 4:16 pm
Some playing around.
Fitted up the torsion bar and put some wheels on so I can move it aroud the back yard.
Have dry fitted some plates to weld the draw bar to, still playing with Ideas.
niterida
Post by niterida » Thu Mar 01, 2012 7:37 pm
Why don't you turn it around so that it is facing backwards, remove the window and cut the roof section so that it looks like a spoiler ?
Or just cut the entire roof section off and just use the tray.
revmax
Post by revmax » Thu Mar 01, 2012 7:55 pm
niterida wrote:Why don't you turn it around so that it is facing backwards, remove the window and cut the roof section so that it looks like a spoiler ?
I Like that , But if the back wall was made into a tail gate then the spoiler would get in the road unless you are a midget.
I think if the roof section was cut off it would be more practicle but would loose the Brumby look.
I have a flexiglass canopy that will be fitted so it will be a sealed trailer.
alang
Post by alang » Thu Mar 01, 2012 8:16 pm
If you make a box in the old cab area to hold a keg and gas bottle take the window out and have a bench top over the box so it will hold your beer glasses and beer tap place a spar in the ute section would make a great party trailer. Something like this but better
http://www.weeklytimesnow.com.au/articl ... ddock.html
thunder039
Post by thunder039 » Thu Mar 01, 2012 8:24 pm
cant wait to see the finish product.
keep up the pics! might have to give this ago with my spare brumby. got any idea what it would wiegh?
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
Post by Gannon » Thu Mar 01, 2012 9:37 pm
Food for thought, ex member 'Mechawagon' or Ben, made a boat trailer using the 2wd rear end from my MY sedan.
IMGP0057 (Medium).jpg (59.12 KiB) Viewed 4250 times
IMGP0024 (Medium).jpg (52.79 KiB) Viewed 4250 times
revmax
Post by revmax » Fri Mar 02, 2012 5:13 am
alang. That is a great Idea.
Thunder. yep will do, Picking up some 50x75x3 RHS Gal today. Nah sorry no idea on what it will weigh as yet.
Gannon that is pretty neat, did he leave provisions for shockies. I like the A frame onto a single bar idea and will use it.
Post by Gannon » Fri Mar 02, 2012 5:21 am
Nah just using the torsion bar, its only for a tinnie
alang
Post by alang » Fri Mar 02, 2012 7:37 am
Gannon wrote:Food for thought, ex member 'Mechawagon' or Ben, made a boat trailer using the 2wd rear end from my MY sedan.
That would be a good way of putting independent suspension under a camp trailer too :-D
