Brumby Identification, hints etc
Well, the oil leak wasn't the gasket, so we found out yesterday when commencing to remove the pump. The plate is fractured completley through. What a pain in the *&^%. Ok guys, what are the tricks to removing the pump, I suppose the front pulley needs to be removed, however it seems to be roomy enough to dislodge the pump, but maybe not enough. Points on Scotching the engine on this breed to loosen the pulley retaining bolt?
