EJ Dual Range AWD 1.19:1 Lo range upgrade to 1.59 {56k warning}
- kiwi_subaru
If its EA82 dual range gearbox non turbo its 1.59:1. If its Turbo box its 1.19:1 I think? Can someone confirm?
Ok, new update.. I'm doing up another 1.59:1 low range conversion for EJ box with EA low range.
This time I've picked Gen 1 1991 Liberty box because this bloke wants 3.9 final drive which this gearbox has.
Opened it up, and changed as normal progress like what I did in this post.
One thing that I learned which makes life easier is this (its a High/Low synchronizer hub) -
YOU do not need to machine it if you are going to use Gen 1 Liberty's main shaft as the measurements are the same as EA box.
Whereabouts Gen 2 gearboxes onwards you do need to machine the High/low synchronizer hub like what I've shown above. Here is a picture of un-machined High/low synchronizer hub.
So in theory - I believe it would be approx 15% stronger if you used Gen 1 Liberty gearbox instead of using Gen 2 Liberty/onwards gearboxes.
SO if you are planning to convert the gearboxes I strongly recommend Gen 1 box and you can change final drive ratios & 5th gear ratios etc...
Yep mate it is still good...dibs wrote:so hows the box going you still smiling????????????????????
dibs
On other day about 4 weeks ago, I had to pull up an Commodore on a car trailer on my mates farm where he couldn't pull it up with his Rodeo (would loose traction on grass) so I wacked in low range and pulled it up - works like a treat - he was gobsmacked..
Hey AP..
I have a 8 bolt Outback gearbox (99 model) here that has bearing problems and wish to pull apart at some stage.. Do you think the EA D/R internals will fit?
Paul
Paul
Paul I'm pretty sure the internal layout is still the same, just the number of bolts to mount the engine have changed.RSR 555 wrote:I have a 8 bolt Outback gearbox (99 model) here that has bearing problems and wish to pull apart at some stage.. Do you think the EA D/R internals will fit?
If it's a 4.11 or 4.44 diff ratio, to fit the L low range you'll have to shave some meat from the crown wheel. I'm not sure which section needs to be removed as I've not done it or seen it done myself. Peejay will be able to elaborate more I'm sure.
I really hope so.. as for the ratio, I'll grab the number off the box and see. I remember building a 4.4 many years ago and have to skim some of the crown wheel were it bolted to the diff centre flange.. Thanks budEl_Freddo wrote:Paul I'm pretty sure the internal layout is still the same, just the number of bolts to mount the engine have changed.
Just curious, is it a certain type of EA D/R box needed to be used as a donor? I bought 2 EA D/R boxes to use on my 2 liberty boxes. The shaft that the 2 dual range counter gears sit on is thinner in diameter than the shaft from my EJ box. I was so hyped to be able to test it in the mud, but now I can't do it & need to buy another 2 gearboxes. Doh.
G'day s3gti, welcome to the forum!s3gti wrote:Just curious, is it a certain type of EA D/R box needed to be used as a donor? I bought 2 EA D/R boxes to use on my 2 liberty boxes. The shaft that the 2 dual range counter gears sit on is thinner in diameter than the shaft from my EJ box. I was so hyped to be able to test it in the mud, but now I can't do it & need to buy another 2 gearboxes. Doh.
What year is your EJ gearbox from? And the EA boxes? I've not heard of this happening before.
Have a read in the Subaru Chat part of the forum on how to host images and drop a couple in here to show us what you're talking about exactly
I'm sure we'll nut it out without the need of another set of gearboxes.
Lets see if I can do this right, these images should be able to tell the story.
These are hopefully the gears in question. It worked.
These are the 2 sets of low range gears. the liberty is on the right- with the writing on it.
The two shafts side by side
& an end-on pic showing the different diameters.
The liberty gearbox is out of a 91 liberty & the other box is an ea series dual range box. Perhaps it is out of an 1800 wagon, or brumby. I know that it has a final drive of 3.7:1, & that now I have 2 of them in pieces.
Good point Toonga!TOONGA wrote:You ned to get an L series 5 speed box and use the low range gears out of that. the brumby/ wagon /MY series gearset will not work.
s3gti, the gearboxes you've got for the swap - are they a 4 speed or a 5 speed? Got pics of the gearbox casings? I should be able to let you know if it's 4spd or 5spd by the casings if you don't have one that's still together
Here's the problem - the MY or brumbys only came out with a 4 speed gearbox in high and low range 4wd...s3gti wrote:Pretty sure they are a 5 speed box, same number of cogs as the liberty box. I think it may be like toonga says, the boxes are probably from an 1800 wagon, or brumby. I wish I knew that before I bought the bloody things. Oh well, s#@t happens. thanks for your help.
Can you load us up a couple of images of these gearboxes? And if you've got them split a shot like this would help:
I hope you're not giving up on this!
- fårwildrajv
Hello!
you seem to be good at subaru gearbox.
I have a question...
is there a needle bearing on the inputshaft between the HI and LOW speed?
Im sorry if my English is bad and some word get wrong... I live in sweden
My problem is a bearing noise when i drive in HI but not in LOW so my guess is a bearing between the HI and LOW.
Thanks!
Thanks!
- vxlsubba.jpg (87.31 KiB) Viewed 28552 times
To the best of my knowledge, the bearings supporting the input shaft are the big wide thing to the right, and the thin one in the wall of the casing behind the diff.
When the synchro is engaged, it locks the 2 pieces of the shaft together.
However, when the synchro is the other way, the load goes via the side shaft via the gears which is hidden behind in that pic.
That short shaft is on bearings also, so that might be the problem area.
Anyone disagree?
Anyone disagree?
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
:???:Previous rides:
