impreza running rough as guts/backfiring
It will continue to scroll through all codes but yours appears to have just the one.. #12
Ok.. Code 12 is the Ignition Start Signal, so I'd replace you Ignition Relay.
This is the little light brown coloured relay behind your inside fuse box (bottom RHS of your dash). I'd see if you can borrow someones that is known to be good, as they aren't cheap to buy. Thinking about it, someone made a post relating to changing them for standard 87a relays.. let me see it I can find it.
If you try the above and it works, try and do this conversion...
showthread.php?t=19809&highlight=ignition+relay
I'm going to say yes but very hard to tell over the net. This is why I'd try it first with a known good one, then make the changes if it works. I have seen Subarus do some weird sh*t when these Ignition Relays play up.
These Ignition relays are the same from the early Gen1 (BC/BF) and Gen2 (BD/BG) Libertys, early Imprezas (GC/GF model) and the early Foresters (SF models). Not sure what other ones use them but this should give you a good range of cars to try from.
You could also try going to your local wrecker and if you have a good rapport with them, they might let you try one first?
I hate to ask but how much do you think a mechanic would charge if it does turn out to be the problem,i have had a look at a few wrecks on ebay see if they get back to me have to ring mate from all things soobaroo they have closed now but he may have some stuff laying around.
Now-00 Impreza 00 GT Forester
Then-5xVortex's Glf Hardtop
Have you read the relay conversion thread? It seems pretty straightforward to do, esp if you have someone to help you who is confident with wiring...
showthread.php?t=19809&highlight=ignition+relay&page=2
Make sure you read the thread from post 1, it has all the necessary info. One of the later posts mentions problems similar to yours so I'd def give it a go. From whats been said on the thread, if you get a OEM relay from a wrecker, chances are you'd be putting in another faulty relay. You'd have to check its ok 1st. As Paul said, try one from a known fault free car.
Also, make sure you have a Jideco ignition relay, 2M (MR5A414A1K12V)
My personal opinion is do the conversion as its cheap, effective & not too hard.
I'm guessing too much, so best to try it yourself.GTFOZZY wrote:I hate to ask but how much do you think a mechanic would charge if it does turn out to be the problem,i have had a look at a few wrecks on ebay see if they get back to me have to ring mate from all things soobaroo they have closed now but he may have some stuff laying around.
Hi guys need a hand,have found the relay but wiring is different to the diagram on here.Can anyone help me out
[img]<div%20style="width:480px;text-align:right;"><embed%20width="480"%20height="360"%20src="http://static.pbsrc.com/flash/rss_slide ... ></a></div>[/img]
If I had the wiring diagram for your car then no sweat but I don't have one in front of me. Try search on here for a wiring diagram for your exact model.
Yeah its not the same but very similar.
Gannon is very good with this kinda thing, maybe PM him.
Note that in your photo you're looking at the back of the plug where the wires come out which is the reverse of the diagram (plug face).
So at a guess (NOTE: GUESS), the wires on YOUR plug correspond to the diagram:
thin green: wire 2 - ECU switched power
thin black : wire 1 - ground
yellow/red : wire 4 - ECU
yellow/blue : wire 3 - various
black/red : wire 5 - fuel pump relay
black/red : wire 6 - fuel pump relay
Ah this may be incorrect, the start signal is what the ECU receives only while you are cranking the starter motor. Last time I checked my codes in my Outback, it was there too. I have not checked if it came back.RSR 555 wrote:
I'd be finding an ignition coil off a working car, along with new leads and trying that
