AWD ratios
chubby37
AWD ratios
Post by chubby37 » Sun Oct 23, 2005 10:56 pm
anyone know whats the go with awd boxes????i got one and was told it,s 3.7 but the i read this....
Full-Time 5spd Single Range
Full Time version of the 5spd Single-Range, with open center diff and center diff lock. It has 25 spline axles stub and 3.9 final gear. It came exclusively with the XT-6 models. 2-piece driveshaft
anyone know??does this mean any awd box or some other one?
daza
Post by daza » Sun Oct 23, 2005 11:22 pm
Hey,
if you can put it in 5th, you could turn the CV's and count how many times the input shaft turns?
hoping it's a 3.7 hey...
chubby37
Post by chubby37 » Sun Oct 23, 2005 11:26 pm
ok.....heck yeah....i think i,ll be right but i know how my luck runs
daza
Post by daza » Sun Oct 23, 2005 11:31 pm
Yep, i know just what you mean, if you didn't check it, it would definetly have been wrong...
Post by AndrewT » Mon Oct 24, 2005 12:00 am
Wouldn't you have to put it in 4th gear for that?
I thought 4th gear is usually the 1:1 ratio.... correct me if I'm wrong tho!
Suba
Post by Suba » Mon Oct 24, 2005 10:01 pm
Turn the thing upside down , pull out the drain plug and you should be able to see the crown wheel, count the teeth , if there is 37 it is 3.7.
Mike.
aspro
Post by aspro » Mon Oct 24, 2005 10:58 pm
Mike is on the money, easiest method is to count the teeth...too easy!
daza
Post by daza » Tue Oct 25, 2005 6:30 pm
i can't find any confirmation but i think AndrewT is right with 4th being 1 to 1?
Post by El_Freddo » Fri Oct 28, 2005 6:41 pm
usually 4th is one to one, fifth being an overdrive, that's how the new cars get the good economy with the extra power, noticed we're getting 6 speed manuals in performance vehicles (such as holden) now?
anyways, hope this is right, its usually the case, otherwise i don't see any use in the fifth gear excpet that you have closer gears ranges in the lower gears...
El Freddo
(aka Bennie)
BaronVonChickenPants
Post by BaronVonChickenPants » Fri Oct 28, 2005 6:54 pm
According to the info I found on USMB (I never said it wasn't useful) your gear ratios are
1st-----2nd----3rd-----4th-----5th----Final
3.545--2.110--1.448--1.088--0.871--3.7
No garuntee on acuracy but hope it helps.
Jordan
