impreza running rough as guts/backfiring
GTFOZZY
Post by GTFOZZY » Mon Jan 16, 2012 9:37 am
Yeah checked all the air filter box etc replaced filter not that but i will keep in mind.it has run silly due to this before so i checked that first :P
GTFOZZY
Post by GTFOZZY » Mon Jan 16, 2012 4:58 pm
Ahhhh couldn't get the leads from sca apparently you can only get genuine for my model :/ so rang our mechanics boxer service and $43 for one lead.... gezz!
Post by NachaLuva » Mon Jan 16, 2012 8:05 pm
GTFOZZY wrote:Ahhhh couldn't get the leads from sca apparently you can only get genuine for my model :/ so rang our mechanics boxer service and $43 for one lead.... gezz!
I went through a huge ordeal trying to find leads to fit my EJ20J engine, finally found some NGK leads which were the only aftermarket leads to fit! Got them from Bursons.
Genuine leads I'm sure are very good but $43 each???
Do you know what model engine you have? I'm guessing EJ202?
GTFOZZY
Post by GTFOZZY » Mon Jan 16, 2012 8:30 pm
yeah an ej20 its a 2lt 2000 standard impreza,i know rather expensive hey! would be cheaper for the foz im guessing :/ damm cars lol
Post by NachaLuva » Mon Jan 16, 2012 9:39 pm
GTFOZZY wrote:yeah an ej20 its a 2lt 2000 standard impreza,i know rather expensive hey! would be cheaper for the foz im guessing :/ damm cars lol
Yeah cars are a great way to lose heaps of money lol :rolleyes:
AFAIK the engine's the same regardless of the car its in, I think you have an EJ202. it will be on your compliance plate. Does it have 4 straight coil ends or are 2 right angled? The end of the lead that goes on the coil...
Post by Alex » Tue Jan 17, 2012 9:31 am
nachaluva wrote:Yeah cars are a great way to lose heaps of money lol :rolleyes:
im pretty sure itll be an EJ201, thats whats in my liberty. I think they feel abit more pokey than an EJ202.
try a different parts supplier, we have a joint in WA called veales who deal parts to mechanics and i have no doubt theyll be able to find leads for less than $43 ea. SCA are a bunch of useless kids and only worth buying LEDs and neons from.
Post by El_Freddo » Tue Jan 17, 2012 1:15 pm
You will be able to get them after market! As Alex has said forget supercrap and autoblah, you need to find a mob actually deals with parts with proper catalogues and suppliers.
My local is independent and are great with finding parts when I need them - only when they can't actually find an aftermarket item that's easily available they'll give me a call to get approval of ordering in a genuine item... Good service there too.
GTFOZZY
Post by GTFOZZY » Tue Jan 17, 2012 5:14 pm
yeah i know they are useless,however have a good relationship with our mechanic but still pissed at that price,could i ask who your supplier is,as I do a lot work myself and needs parts fairly regular?
GTFOZZY
Post by GTFOZZY » Thu Jan 19, 2012 8:08 am
gah! replaced lead still running like crap :/ i guess try the other things you all mentioned if that doesnt work off to the mechanic i spose :/
GTFOZZY
Post by GTFOZZY » Fri Jan 20, 2012 7:25 am
Does anyone think the coil could have something to do with it?
Now-00 Impreza 00 GT Forester
Then-5xVortex's Glf Hardtop
Post by Alex » Fri Jan 20, 2012 8:54 am
I would have replaced all the leads. Coil would cause issues but the coils are extremely reliable.
Sent from my HTC Desire using Tapatalk
Smokey
Post by Smokey » Fri Jan 20, 2012 11:22 am
Ignition relay related?
Post by NachaLuva » Fri Jan 20, 2012 2:28 pm
GTFOZZY wrote:Does anyone think the coil could have something to do with it?
You'd better hope not. I've been quoted $800+ genuine for mine, $400+ cheap chinese crap! :(
What did the old plugs look like? They tell a story of whats happening inside your engine. If all 4 plugs are fouled, could be the coil. Could aslo be other things too...
Also, I agree, I'd be replacing all the leads.
longy99gt
Post by longy99gt » Fri Jan 20, 2012 3:53 pm
like some guys said,
the fuel filter is often forgotten,
and the air flow meter,
I've gone thru about 4 of them over the years
doesnt take much to piss them off...
if you do plugs, make sure you put platinum plugs back in!
not cheapies....
speaking of which, my car needs a good service, oil and filters done....should get onti it,
have a good weekend fellas
"SUUBMARINE"
20" LED Front Light Bar
Post by RSR 555 » Fri Jan 20, 2012 9:28 pm
Are you running an aftermarket air filter? like the oiled ones?
GTFOZZY
Post by GTFOZZY » Sat Jan 21, 2012 12:51 pm
No just stranded air cleaner.
Post by RSR 555 » Sat Jan 21, 2012 4:09 pm
Do you have any codes?
Do you have a friend with a similar car that you could try parts off?
GTFOZZY
Post by GTFOZZY » Sat Jan 21, 2012 7:48 pm
I might sound dumb so sorry but how do i get codes i dont have a comp or anything and no,no friends with similar car :/
Post by RSR 555 » Sat Jan 21, 2012 9:26 pm
GTFOZZY wrote:I might sound dumb so sorry but how do i get codes i dont have a comp or anything and no,no friends with similar car :/
Not at all bud.. it's no probs. Just stick your head under the steering column and behind the dash panel, you should see 2 black plugs (and 2 green ones but we don't need those unless your 'Check Engine' light is one?) once the black plugs are joined, turn your ignition on so the dash lights all come on (at this stage you should hear the radiator fans cycling) and then count the flashes on the 'Check Engine' light. 1 long flash = 10 and 1 fast flash = 1. So if you had an issue with say your Air Flow Meter, you'll end up with 2 long flashes followed by 3 short flashes (23). These are codes in memory and hopefully we might find something that is shonky.
GTFOZZY
Post by GTFOZZY » Sun Jan 22, 2012 6:26 am
ok so i will give this a go and get back to ya
