Long story short.
I have recently converted my carby L series to EJ22. After that I had a few issues where the engine was in limp home mode, ecu controlled fan stayed on all the time. (with ign on) and it was bumping up the idle..
After some chatting and hard work with RSR 555 (Paul) with figured that it needed the vehicle speed sensor hooked up so the ecu knows how fast the car is going so it doesnt freak out. Being a carby L it had no VSS so we painstakingly put a EFI cluster with the VSS in it into my L. (look out for a 'how to' post later on possibly)
At the time as well as the vss code (33) getting a purge valve code (35) and coolant sensor code (21).. After replacing the purge valve just to get rid of the code, i erased the codes and all was sweet..
Then after driving for a about 10mins the Eng light (code 33, VSS) came back on, engine fan stays on and idle bumps up to 1k.
I put it into test mode briefly (green plugs together) then start her up n go for a drive and then about the same time later light comes back on etc etc..
My thought is a faulty VSS from the EFI cluster (not that im complaining about it, it looks great with the factory tacho and fuel light made into engine light
Was thinking of hooking an LED to the VSS wire and monitor its bahaviour and see when it flips out??
Any ideas anyone?? Don't hold back, even blame me i dont care i just need to sort it out
