Dual cab brumby
- maudsland
Dual cab brumby
here is an interesting conversion, make a 4dr dual cab from a brumby and sedan, from what i can see cut the brumby infront of the b pillar and the sedan behind the b pillar cut and shut some doors for the rear and the sedan glass should line up with the brumby b pillar angle. All i need is a good brumby rear, sedan front, gas axe and a place to do it. Who is interested
just a quick chop here.
Just thought you may like to see this, took about 20mins to do, but I got time
Its a Brumby with L series doors, I couldn't find a MY sedan so I just used a L series instead. Its all the same anyhow right?
Hope you like it...
Hope you like it...
- BaronVonChickenPants
Nicely done, mate your a genius with photoshop, I planned to make a photoshoped dual cab brumby ages ago but never got around to it, can garuntee mine wouldn't have looked half that good.
Once upon a time I considered building a dual cab brumby, never got any further than being hypothetical, I was thinking of using something like a land cruiser troopy chasis with the dual cab brumby body on top, then run something like an EJ25 or EZ30 either into the cruiser drivetrain or into an EA82 box with a divorced transfer case, but still using the cruiser discs, hubs, wheels, etc.
You would probably have to register it as a unique vehicle, which means it would have to comply to all current adr regulations.
Would definitely be a fun project though.
Jordan.
Jordan.
- tim_81coupe
You can fit 3 kids or 2 well folded adults
Adult installation instructions for MY and L series rear seats:
Fold legs at hips (forwards or backwards) until knee's can be inserted into ears, bend legs at knees until toes can be inserted in arse, wrap arms around shins tightly and tie together, place on rear seat, fasten seat belt and tighten.
Jordan.
Jordan.
How about a bench seat Brumby?
OK, so maybe a dual cab Brumby isn't too practical if the tray's not extended, although it would be a great project...has anyone converted the front seats to allow 3 people across? Is there an existing bench seat somewhere and would regulations allow 3 across in a Brumby or Touring Wagon or whatever?
- tim_81coupe
Its called a Baja. Is the USA the only country that gets the Baja?
