Ok this is for my ej25 L-seires build. A little bit of history first.
When i had my ej22, both fans were running off the ECU and the car used to overheat as soon as i went off road. Turns out the ECU wasn't supplying enough to power for both fans and they were working at about 35 and 65% of their capacity. So to solve this i only hooked one fan via the ECU and the other was with a switch. This improved greatly the cooling power of the fans and the car would only overheat when i forgot to turn the manual fan on, LOL. Fans used were two ebay 12inch, Placed between the engine and radiator.
For the new build, I went with two 10inch Davis Craig fans as i was placing them in front between the radiator and the front grill and they had to be smaller. From the specs of the 10 inch Davis Craig and the 12inch ebay specs, the 10 inch Davis Craig are said to displace a similar amount of air. I guess this is because they are a better quality brand.
Anyway I was able to squeeze one of the 12 inch ebay fans in between the engine and the radiator opposite to one Davis Craig fan. I thought the more the better but than Dave had a good point.
![Image](http://img27.imageshack.us/img27/307/sdc19471.jpg)
He pointed out that if the DC fan was pushing more than the ebay one, the ebay would be useless and actually restrict the air flow in a way.
Basically what i wanted to know are your thoughts on this. Is that true or not?
I wanted to add the third fan as the air flow needs to go trough my twin core radiator but also the air-con condenser and though it might help to flow better.
What do you guys think? Should i keep it or remove it?
