The sheet metal sticking out the front is just the leftovers I chucked in there to move somewhere else.
Started off with a rego'ed 6x4 trailer with good frame but totally rusted out body, and the rear half of my first L series wagon that's been sitting around for years.
Cut the body off the donor trailer.
Made a frame in the L series body out of new galvanised box section and welded it to the frame from the donor trailer.
Welded hinges to the bottom of the L series tailgate so it folds down instead of up now.
Fitted a 2wd K frame to the L series body (had one sitting there with near-new bearings in it).
Put the old pair of KYB shocks and Kings springs out of Monsterwagon into it.
Put 3" body lift in it and fitted a couple of old 14" speedie rims with pretty knackered (but good enough) 27" tyres.
Welded some small box down the top edges to make it more practical for loading stuff.
Made a floor for the part which lowers down where the rear seats used to be, continues along the same level as the wagon floor at the back.
Wired the lights up to a 7pin trailer plug.
Spent maybe 6 or 7 hours on it I spose. Bought some Mig wire and new box section and sheet, used other offcuts and junk I had lying around.
Still needs quite alot of little attention to detail;
- grind down all the little sharp edges and close off voids with light sheet
- enclose the front section with a wall (removable with wing nuts tho incase I want to load extra long stuff)
- fit a jockey wheel
- fit a spare wheel/tyre
- might replace the hitch with one with a hydraulic master on it and connect up the drum brakes...but not really necessary for a trailer this size
- might find some Honda springs to beef it up abit
- delete the tow bar :P
It's roughly 6.5x4x5 size - little bigger than the standard 6x4 trailer size but sortof evens up because it has wheel arches inside taking up abit of room.
Bit of a laugh but way better than what it was
