Rear park light removal - brumby
555Ron
[Solved] Rear park light removal - brumby
Post by 555Ron » Sun May 22, 2011 12:21 pm
Hi, i can't get my park light out of the assembly for a 92 Brumby. The Gregory's manual says to rotate it anticlockwise and remove the bulb holder. I've rotated anti-clockwise 360 degrees and it hasn't wanted to come out. Anyone know how far to rotate it before it should pop out? It's extremely stiff! Thanks.
Post by steptoe » Sun May 22, 2011 12:43 pm
No, pull the lens off and remove bulb from the inside, please......
555Ron
Post by 555Ron » Sun May 22, 2011 1:51 pm
Cool, thanks Steptoe. Didn't want to break the plastic. All fixed now, thanks, Ron.
555Ron
Post by 555Ron » Sun May 22, 2011 8:11 pm
Ok, after a little thought i have some more questions...
I want to have my headlights wired up to the ignition so if i turn the key off - the lights will turn off too. (My old L Series was like this and i don't think i can get used to having to turn the lights off) I am thinking if i run the switched wire from the radio to a SPDT relay and then run the parkers and low beams through the poles this should achieve my aim. Does anyone have objections or a better idea? I did a bit of doodling on the wiring diagram and i think i need to switch the red (RW) and blue(RB) wires. I am planning on cutting into them just as they come out of the headlamp switch in the dash. Good plan??
Next is my aerial is broken. Can i get an aftermarket one at Repco?Is it possible to install an aftermarket one that automatically retracts when you turn it off? Would the Guard have to come off? Thanks...
wiring diagram.jpg (112.3 KiB) Viewed 1590 times
David D
Post by David D » Sat May 28, 2011 2:09 pm
I got an aerial for my Brumby in Autobarn for around 40 bucks. It's an aftermarket one and I think it just said Subaru Top Mount on the packet. The bracket is a slightly different angle but I just used my existing bracket which was fine - only my aerial was snapped. It also came with a new plastic trim thing. This is not an electric aerial tho, just the old school manual one. I didn't have to take the guard off, just the arch liner.
David
